#include <SoftwareSerial.h>
SoftwareSerial SIM900A(8,9);
SIM900A.begin(9600); // GSM Module Baud rate - communication speed
Serial.begin(9600); // Baud rate of Serial Monitor in the IDE app
Serial.println ("Text Messege Module Ready & Verified");
Serial.println ("Type s to send message or r to receive message");
if (Serial.available()>0)
switch(Serial.read())
case 's':
SendMessage();
case 'r':
RecieveMessage();
if (SIM900A.available()>0)
Serial.write(SIM900A.read());
void SendMessage()
Serial.println ("Sending Message please wait....");
SIM900A.println("AT+CMGF=1"); //Text Mode initialisation
Serial.println ("Set SMS Number");
SIM900A.println("AT+CMGS=\"+639927961461\"\r"); // Receiver's Mobile Number
Serial.println ("Set SMS Content");
SIM900A.println("Bhai kya haal hain? (Brother how are you?) this messege has been sent through Arduino Uno not a mobile phone wink wink ");// Messsage content
Serial.println ("Done");
SIM900A.println((char)26);// delay(1000);
Serial.println ("Message sent succesfully");
void RecieveMessage()
Serial.println ("Receiving Messeges");
delay (1000);
SIM900A.println("AT+CNMI=2,2,0,0,0"); // Eeceiving Mode Enabled
Serial.write ("Messege Received Sucessfully");
Your topic was MOVED to its current forum category which is more appropriate than the original as it has nothing to do with Installation and Troubleshooting of the IDE
When you send commands to the modem, it's not enough to just wait after each command - you need to receive and analyze the modem responses. The next command should be sent only after you receive the "OK" response to the previous one.
case 's':
SendMessage();
case 'r':
RecieveMessage();
if (SIM900A.available()>1)
void SendMessage()
delay (1000);
Welcome to the forum
please edit your post, select the code part and press the </> icon in the tool bar to mark it as code. It’s barely readable as it stands. (also make sure you indented the code in the IDE before copying, that’s done by pressing ctrlT on a PC or cmdT on a Mac)
Why 1? 0 should be fine
Please do not cross-post
This message is copy of this one:
Flagged to moderator
Your two topics on the same or similar subject have been merged.
Please do not duplicate your questions as doing so wastes the time and effort of the volunteers trying to help you as they are then answering the same thing in different places.
Please create one topic only for your question and choose the forum category carefully. If you have multiple questions about the same project then please ask your questions in the one topic as the answers to one question provide useful context for the others, and also you won’t have to keep explaining your project repeatedly.
Repeated duplicate posting could result in a temporary or permanent ban from the forum.
Could you take a few moments to Learn How To Use The Forum
Thank you.
