help me to connect Weighing indicator to arduino via usb
my device is arduino uno and rs232 module.
i connect rx and tx rs232 module to arduino in pin 0 for rx and 1 for tx.
Asynchronous, bi-directional, half-duplex
Data format Baud rate: 1200, 2400, 4800, 9600 bps
Data: 7 bits + parity 1bit (even or odd) or 8 bits (non-parity)
Start bit: 1 bit
Stop bit: 1 bit
Code: ASCII
Terminator: CRLF (CR: 0Dh, LF: 0Ah)
This is a sample of the string generated:
S T , G S , + 0 0 1 2 . 3 4 5 gCR LF
If I open excel or notepad, data is continuosly written to application.
This is a sample of how the data is outputted:
ST,GS,+0012.345g
ST,GS,+0012.345g
ST,GS,+0012.345g
ST,GS,+0012.345g
The data is outputted about every 100ms
If I open a terminal emulator such as putty and connect at with the same vaules I’m attempting to use with my code, I see the same output.
I’m using the example code found in the arduino library. and the output in serial monitor is always -1 .
please help me!!
// include the SoftwareSerial library so you can use its functions:
#include <SoftwareSerial.h>
#define rxPin 0
#define txPin 1
// set up a new serial port
SoftwareSerial mySerial = SoftwareSerial(rxPin, txPin);
// define pin modes for tx, rx:
pinMode(rxPin, INPUT);
pinMode(txPin, OUTPUT);
// set the data rate for the SoftwareSerial port
mySerial.begin(9600);
Serial.println(mySerial.read());
No one else has EVER been able to do SoftwareSerial on the hardware serial pins while also using them for hardware serial. What makes you think you are special?
change “#define rxPin 0” and “#define txPin 1” to some other value may be “#define rxPin 2” and “#define txPin 3” for softwareserial (mySerial) since pins 0 and 1 are for the hardware serial which is used by the Serial monitor
i change rxpin and tx pin to 2 and 3 but nothing change. my code can read data 8 data bit 1 start bit from PC to arduino and my weighing* can deliver data to rs com using 8 data bit and 1 start bit. how to connect my weighing* to arduino using rs232?
*my weighing is And EK-300i
You could post a link to that device AND a schematic showing how it is connected to the Arduino OR you can solve your problem yourself. Your choice.
