Help Me to find coding for geiger counter portable M4011 models NGMC V1
:confused:
help me to find coding for geiger counter portable models m4011 ngmc v1, My deadline for my thesis menyeleseikan I made a radiation monitoring system and I buy geiger counter m4011 models ngmc v1, but I can not use it because I do not know coding, I've tried using the coding of other products but can not, so I beg the master to help me find the coding for geiger counter m4011 mopdel ngmc v1 product of cajoe
Hi, Have you googled
also try here;
https://forum.arduino.cc/index.php?topic=336041.0
Tom.... :)
thanks for its support, but if I use the coding result obtained is always 0, but already I gave the radioactive material, and geiger tube was responding but the result value is always 0
Can you please post a copy of your sketch, using code tags?
They are made with the </> icon in the reply Menu.
See section 7 http://forum.arduino.cc/index.php/topic,148850.0.html
Tom… :slight_smile:
You've seen this ? https://forum.arduino.cc/index.php?topic=336041.0
Edit. I didn't see TomGeorge posted the same link earlier. Sorry.
thisi is my code
#include <SPI.h>
#include <SoftwareSerial.h>
#define LOG_PERIOD 15000     //Logging period in milliseconds, recommended value 15000-60000.
#define MAX_PERIOD 60000    //Maximum logging period
unsigned long counts;             //variable for GM Tube events
unsigned long cpm;                 //variable for CPM
unsigned int multiplier;             //variable for calculation CPM in this sketch
unsigned long previousMillis;      //variable for time measurement
void tube_impulse(){               //procedure for capturing events from Geiger Kit
  counts++;
void setup(){                                               //setup procedure
  Serial.print("Radiation Monitoring ");
delay(3000);
  Serial.write("at\r\n");
  delay(250);
  Serial.write("at+httpterm\r\n");
  delay(250);
  Serial.write("at+sapbr=0,1\r\n");
  delay(5000);
  Serial.write("at+sapbr=3,1,\"contype\",\"gprs\"\r\n");
  Serial.write("at+sapbr=3,1,\"apn\",\"telkomsel\"\r\n");
  delay(250);
  Serial.write("at+sapbr=1,1\r\n");
  delay(10000);
  Serial.write("at+sapbr=2,1\r\n");
  delay(250);
  Serial.write("at+httpinit\r\n");
  delay(250);
  Serial.write("at+httppara=\"cid\",1\r\n");
  delay(250);
  counts = 0;
  cpm = 0;
  multiplier = MAX_PERIOD / LOG_PERIOD;      //calculating multiplier, depend on your log period
  Serial.begin(9600);                                    // start serial monitor
 // uncommennt if you have time-out problem to connect with Radiation Logger
 //  delay(2000);
 //  Serial.write('0');                                      // sending zero to avoid connection time out with radiation logger
 //  delay(2000);
  pinMode(6, INPUT);                                   // set pin INT0 input for capturing GM Tube events
  digitalWrite(6, HIGH);                                 // turn on internal pullup resistors, solder C-INT on the PCB
  attachInterrupt(0, tube_impulse, FALLING);  //define external interrupts
void loop(){                                               //main cycle
  if(currentMillis - previousMillis > LOG_PERIOD){
    cpm = counts * multiplier;
Serial.write("at+httppara=\"url\",\"http://database-radiasi.16mb.com/input.php?gamma=");
  Serial.print(cpm);
    Serial.write("\"\r\n");
    delay(200);
    Serial.write("at+httpaction=0\r\n");
    delay(3000);
    Serial.write("at+httpread\r\n");
    delay(10000);
                                      // send cpm data to Radiation Logger
    counts = 0;
no error but the result always 00000 ,and not random
i hpe you can help me
thank you
Hi, Thanks for the pictures, but we need a circuit diagram of how you have connected the counter to the arduino?
Thanks.. Tom.. :) Can you indicate where the output of the counter is on the picture please and do you have any documentation on it?
Found this in the thread I linked.
Tom… :slight_smile:
I do not use port (interface to PC audio input) and (two power inputs), does it matter? I do not understand you mean but I only use 3 pins in the module m4011 ngmc v1 geiger counter, namely ground, 5v and vin, other than that I do not use it
Hi, How do you use the Vin, how do you connect it to the arduino. Have you got Vin connected to the digital pin 6?
Please a wiring diagram showing how the arduino is connected to the counter.
Tom... :)
yes i connect vin with a pin 6 on my artificial arduino,
sorry I do not have the diagram, I just try to assemble themselves according to the video that I see,
because the module reference geiger tube m4011 ngmc v1 does not exist, therefore, my friend and I tried to assemble these tools as much as possible
this is the photo
Hi;
Thanks, so its a 328 in minimum component use. Is the 0 reading at the radio logger, or at the 328? Are you sure your radio link is transmitting valid data?
PLEASE! !! Can you please post a copy of your circuit, in CAD or a picture of a hand drawn circuit in jpg, png?
Tom..... :)
