Help me to make a programation code to my project
Hi everyone, I am developing an automatic irrigation project using arduino, but I am very new to the programming area and I need your help to develop the code: the system should work as follows: the soil moisture sensor will read Of the soil and if it is dry will drive the pump and do the irrigation and if the soil is wet the pump will not effect the irrigation.
I count on your help. hugs
You don't say which soil moisture sensor that you have, but if you Google "soil moisture sensor arduino code" you will find lots of information on them. You will need a driver for the pump as the Arduino can't supply enough current by itself. Google "Arduino DC motor control" for info on that subject. You need to know the rated voltage of the motor and the stall current to be able to choose a driver.
