Hi, I'm new in Arduino and in programming generally.
And here is my very first code, which changes the state of green & red leds when pressing the button. But i think there is the better way to do that. If so please show me how.
const int buttonPin = PUSH2; // the number of the pushbutton pin
const int green = GREEN_LED; // the number of the LED pin
const int red = RED_LED;
// variables will change:
int buttonState = 0; // variable for reading the pushbutton status
int ledState = 0;
pinMode(green, OUTPUT);
pinMode(red, OUTPUT);
pinMode(buttonPin, INPUT_PULLUP);
digitalWrite(green, HIGH);
void loop(){
buttonState = digitalRead(buttonPin);
ledState = digitalRead(green);
if (buttonState == LOW) {
if (ledState == HIGH) {
while (buttonState == LOW){
digitalWrite(green, LOW);
digitalWrite(red, HIGH);
if (ledState == LOW) {
digitalWrite(red, LOW);
You are doing something when the switch is pressed, which involves waiting for the switch to be released. It would be a lot better to detect the transitions, from released to pressed and from pressed to released, and doing something only when the correct transition occurs.
int currState;
int prevState = HIGH;
currState = digitalRead(buttonPin);
if(currState != prevState)
// A transition occurred
if(currState == LOW)
// from released to pressed
// from pressed to released
prevState = currState;
Put your code to do stuff after the appropriate comment.
There is no need to call digitalWrite() in the while loop. The pins stay at the state you set them to, whether that is HIGH or LOW. They don't revert just because you turn your back.
I will try to explain better. When I press the button i want green led (pin13) to turn on, next time i press the same button i want green led to turn off and red led (pin14) to turn on. And next time green on and red off.
There is my new code. Fixed loops and added delay (Contact bounce)
const int buttonPin = 2; // the number of the pushbutton pin
const int green = 13; // the number of the LED pin
const int red = 14;
int ledState = 0;
void loop(){
delay(50);
delay(50);
So, you want to count transitions from released to pressed.
Then, you want to do something based on the count:
int currState;
byte count = 0;
count++;
if(count > 2)
count -= 2;
switch(count)
case 0:
// do nothing, as the switch has never been pressed
case 1:
// Turn red on and green off
case 2:
// Turn green on and red off
