how do I resolve the queue.h No Such file or directory
Arduino: 1.8.3 (Windows 8.1), Board: "Arduino/Genuino Uno"
In file included from C:\Users\crash_team\Documents\Arduino\libraries\ESP8266WiFi\src/ESP8266WiFi.h:33:0,
from C:\Users\CRASH_~1\AppData\Local\Temp\arduino_modified_sketch_681278\WiFiScan.ino:1:
C:\Users\crash_team\Documents\Arduino\libraries\ESP8266WiFi\src/ESP8266WiFiType.h:26:19: fatal error: queue.h: No such file or directory
#include <queue.h>
compilation terminated.
exit status 1
Error compiling for board Arduino/Genuino Uno.
option enabled in File -> Preferences.
My Code Using Example for testing :
#include <ESP8266WiFi.h>
* This sketch demonstrates how to scan WiFi networks.
* The API is almost the same as with the WiFi Shield library,
* the most obvious difference being the different file you need to include:
#include "ESP8266WiFi.h"
// Set WiFi to station mode and disconnect from an AP if it was previously connected
WiFi.mode(WIFI_STA);
WiFi.disconnect();
delay(100);
Serial.println("Setup done");
Serial.println("scan start");
// WiFi.scanNetworks will return the number of networks found
int n = WiFi.scanNetworks();
Serial.println("scan done");
if (n == 0)
Serial.println("no networks found");
Serial.print(n);
Serial.println(" networks found");
for (int i = 0; i < n; ++i)
// Print SSID and RSSI for each network found
Serial.print(i + 1);
Serial.print(": ");
Serial.print(WiFi.SSID(i));
Serial.print(" (");
Serial.print(WiFi.RSSI(i));
Serial.print(")");
Serial.println((WiFi.encryptionType(i) == ENC_TYPE_NONE)?" ":"*");
delay(10);
Serial.println("");
// Wait a bit before scanning again
delay(5000);
