Help me to send HTTTP POST request to server(instapush)
Hi! Second in a row day i try to send POST request to PUSH-notification server(instapush) via esp8266. So my code i s send to esp8266 is:
AT+CIPSTART=\"TCP\",\"104.239.162.182\",80"
POST /v1/post HTTP/1.1\r\n Host: api.instapush.im\r\n" x-instapush-appid: xxxxxxxxx\r\n"; x-instapush-appsecret: yyyyyyyyy8\r\n"; Content-Type: application/json\r\n\Content - Length: 61\r\n\r\n"; {\"event\":\"gradus\",\"trackers\":{\"temperature\":\"777\"}}";
But it doesnt work - response is 400 (BAd Requset) What i doing wrong? Please help!
What i doing wrong?
You're not posting code. But you knew that.
I do it to make it easier to read. The rest code are "Serial.print()" to esp8266
Thank you for your kind consideration.
Good luck with your problem.
That is probably the server saying something is wrong with the request you sent.
once you are connected, you use AT+CIPSEND to send the data. read the manual.
