Help me understand converting between tm and time_t
I am struggling with converting between a time structure tm and time_t variable. I've been through a bunch of posts but haven't yet figured out what I am doing wrong.
The following code running on ESP32 produces the following response:
base_time date: 11-12-2024 13:14:15
new_time date: 7-8-2019 18:38:31
Why the difference?
#include "TimeLib.h"
  time_t new_time;
  tm base_time = {0};
  char temp_ch[80];
  base_time.tm_year = 2024;
  base_time.tm_mon = 11;
  base_time.tm_mday = 12;
  base_time.tm_hour = 13;
  base_time.tm_min = 14;
  base_time.tm_sec = 15;
  base_time.tm_isdst = -1;
  new_time = mktime(&base_time);
  sprintf(temp_ch, "base_time date: %d-%d-%d   %d:%d:%d", base_time.tm_mon, base_time.tm_mday, base_time.tm_year, base_time.tm_hour, base_time.tm_min, base_time.tm_sec);
  Serial.println(temp_ch);
  sprintf(temp_ch, " new_time date: %d-%d-%d   %d:%d:%d", month(new_time), day(new_time), year(new_time), hour(new_time), minute(new_time), second(new_time));
From the top of my head I think that tm_year should be the number of years since 1900 (e.g., for the year 2024, tm_year should be 2024 - 1900 = 124). And tm_mon is zero-based, so January = 0, February = 1, …, December = 11. For November, tm_mon should be 10.
What is that line supposed to do? "tm" is not defined in the version of TimeLib.h that I use.
Beware of the different epochs used in unix timestamps.
The ESP32 uses the standard C time library, the posted code is mixing references to that library with references to the Arduino Time library, which is not completely compatible.
Thanks, that explains the problem.
Ah, thanks, I didn't realize I was using struct tm from the standard C time lib and time_t from the Arduino TimeLib.h.
What I really want to do is assign values to time_t variables so I can compare and get time differences. The following works, but it seems like the wrong way to do it.
  time_t new_time = now();
  char temp_ch[80];
  setTime(15, 14, 13, 12, 11, 2024);
  new_time = now();
Is there a better way to assign a value to new_time?
FWIW the "base_time = {0}" was because some values in the struct weren't initializing to zero. After adding that, all members of the struct read zero so at least I could start with a known value.
Yes. First, since you're using an ESP32, get rid of 'TimeLib.h' all together and use the C time functions that are already built in. The below code first sets the time zone then builds a local time of 15:00:00 on November 17, 2024. It then converts that to an Epoch time. Then the Epoch time is converted back to a local time using the localtime() function and printed. As expected, the original local date / time is is printed.
Then the code repeats the above with local time 16:00:00 on the same day.
Finally, the two computed Epoch Times are subtracted showing a difference of 3600 seconds (1 hour), as expected.
I've also attached a TZ.h file to pick your time zone. That's easier than setting the POSIX time zone value yourself.
#include "TZ.h"
  const int epochYear {1900};
  char timeString[100];
  delay(2000);
  setenv("TZ", TZ_America_New_York, 1);
  tzset();
  tm localTime1 = {
    0,   // seconds
    0,   // minutes
    15,  // hours
    17,  // day of month
    10,  // month is zero-based
    2024 - epochYear, // years since 1900
    0,
    0,
    0
  time_t epochTime1 {mktime(&localTime1)};
  Serial.printf("Epoch Time1: %lld\n", epochTime1);
  tm *computedLocalTime1 {localtime(&epochTime1)};
  strftime(timeString, 100, "Converted Local Time1: %A, %B %d %Y %H:%M:%S %Z", computedLocalTime1);
  Serial.println(timeString);
  tm localTime2 = {
    0,   // seconds
    0,   // minutes
    16,  // hours
    17,  // day of month
    0,
    0,
    0
  time_t epochTime2 {mktime(&localTime2)};
  Serial.printf("Epoch Time2: %lld\n", epochTime2);
  tm *computedLocalTime2 {localtime(&epochTime2)};
  strftime(timeString, 100, "Converted Local Time2: %A, %B %d %Y %H:%M:%S %Z", computedLocalTime2);
  Serial.printf("\nEpoch Time2 - Epoch Time1 = %lld Seconds\n", epochTime2 - epochTime1);
TZ.h (22.2 KB)
Thank you!
