I have a pressure sensor (MSP40 - GDF) that i want to use in my project. The pressure sensor outputs a max voltage of 75mV. I know I need to boost this to voltage measurable by arduino (Nano). I have choosen LM358 for this task. But Something isn't clear to me:
First Question:
From my understanding of voltage measurement in arduino:
0v = 0
5v = 1023 (integer rep)
if I boost the voltage from my sensor by a factor of 50 then the Max voltage will be 3.75v. This would be 767.25 (max).
I would love to achieve "1023", Do I need to sellect resistors combinations such that I would obtain max 5v in the output of the Op-Amp?
Second Question
LM358 is an IC with two Op-Amps. How do I configure the two Op-Amp to output 5v max with a max input of 75mA?
Ignore one, choose feedback resistors to give a voltage gain of 5/0.075 around the other. However if you want to get a range of 0 - 5v on the op amp output then the LM358 probably isn't suitable, you would need a "rail to rail" op amp. Google is your friend - find tutorials on opamp circuits and data sheets.
A Wheatstone Bridge needs a Intrumentation Amplifier.
There are a number of ways to measure pressure. You have a pressure sensor with a so called "Wheatstone Bridge". That is why the sensor has two outputs: +Output and -Output. There are two -Outputs, you can tie those together.
A normal circuit with a OpAmp has a certain input impedance. A "Instrumenation Amplifier" has a high input impedance, so it does not disturb the Wheatstone Bridge.
You could also forget this sensor and buy a sensor with a normal output, so you don't have this trouble.
The Arduino Uno has a differential amplifier with gain (and also with a high input impedance). That might work, but it is hard to understand and almost no one uses it.
For a test, you could connect +Output to a analog input and -Output to a other analog input. In the sketch you can calculate the difference.
Thank you all for your quick reply. I am happy with your recommendations. But, Since I can get a 5v/0.075v then what advantage will a rail to rail Op-amp be bringing? (just asking for more understanding). I forgot to mention that the min Output voltage of the sensor is 0.001v (which I would love to appear as 0v on the arduino's input).
What rail to rail op-amp will you recommend for this purpose?
OpAmps typically have a restricted output voltage range, like 1V to 4V from a 5V supply. Only rail-to-rail opamps can output their full supply voltage range.
You can use an MCP6002 with R1=1k and R2=62k which will give you a gain of ABOUT 63;
so 0V in will give vout = 0V approx and
75mV in will give 4.725V out
While you COULD trim the values to get close to 0V - 5V out that would not be a good idea as it allows no "headroom". And even true "rail-rail" op amps can not maintain linearity when being worked exactly to their supply voltage limits.
Post the schematic of the part.
If a single opamp is going to be used in a differential amplifier configuration the resistance of the bridge arms will have to be known to calculate the needed gain resistors.
Your other two topics on the same subject deleted.
Please do not duplicate your questions as doing so wastes the time and effort of the volunteers trying to help you as they are then answering the same thing in different places.
Please create one topic only for your question and choose the forum category carefully. If you have multiple questions about the same project then please ask your questions in the one topic as the answers to one question provide useful context for the others, and also you won’t have to keep explaining your project repeatedly.
Repeated duplicate posting could result in a temporary or permanent ban from the forum.
Could you take a few moments to Learn How To Use The Forum
Are you sure about that.
The wheatstone bridge of the sensor could output 2.5volt without pressure,
which is out of range for 1.1volt Aref.
OP shouldn't have bought a bare sensor.
These sensors come for a few dollars more on a breakout board that has an instrumentation amp and a 24-bit A/D included. Yep, a poor man always buys twice.
Leo..
A wheatstone bridge, powered by 5volt, has 2.5volt on it's two outputs.
Pressure generates a differential voltage between those two outputs, which is 0-75mV.
Leo..
