This is my first ever code, can someone please verify things look correct and also answer a question?
after I have put the correct combination to turn on the greenLed how would I go about adding code to put a different combination to turn off that greenLED when I was ready to turn it off instead of the 1000000 delay I have in there now, that way I can keep it on until I want to turn it off
const int button1 = 2; //first button is on pin 2
const int button2 = 3; //second is on pin 3
const int button3 = 4; //third is pin 4
const int button4 = 5; //fourth is pin 5
const int button5 = 6; //third is pin 6
const int button6 = 7; //fourth is pin 7
const int greenLed = 9; //green LED is pin 9
void checkEntered1(int button);
int code[] = {6,5,5,4,3,2}; //the desired code is entered in this array,
//separated by commas
int entered[7]; //create a new empty array for the code entered by
//the user (has 4 elements)
void setup(){ //run once at sketch startup
Serial.begin(9600); //begin Serial
pinMode(button1, INPUT_PULLUP); //button 1 is an input
pinMode(button2, INPUT_PULLUP); //button 2 is an input
pinMode(button3, INPUT_PULLUP); //button 3 is an input
pinMode(button4, INPUT_PULLUP); //button 4 is an input
pinMode(button5, INPUT_PULLUP); //button 5 is an input
pinMode(button6, INPUT_PULLUP); //button 6 is an input
pinMode(greenLed, OUTPUT); // the green LED is an output
for (int i = 0; i < 6;i++){ //work through numbers 0-3
Serial.println(code[i]); //print each digit of the code
Serial.println(entered[i]); //print each element of the entered[]
void loop(){ //run repeatedly
if (digitalRead(button1) == LOW){ //if button1 is pressed
checkEntered1(1); //call checkEntered and pass it a 1
delay(250);//wait, needed for correct functioning, otherwise
//buttons are deemed to be pressed more than once
else if (digitalRead(button2) == LOW){ //if button2 is pressed
checkEntered1(2); //call checkEntered1 and pass it a 2
delay(250); //wait
else if (digitalRead(button3) == LOW){ //if button3 is pressed
checkEntered1(3); //call checkEntered1 and pass it a 3
delay(250); //wait
else if (digitalRead(button4) == LOW){ //if button4 is pressed
checkEntered1(4); //call checkEntered1 and pass it a 4
delay(250); //wait
else if (digitalRead(button5) == LOW){ //if button4 is pressed
checkEntered1(5); //call checkEntered1 and pass it a 4
delay(250); //wait
else if (digitalRead(button6) == LOW){ //if button4 is pressed
checkEntered1(6); //call checkEntered1 and pass it a 4
delay(250); //wait
void checkEntered1(int button){ //check the first element of the entered[] array
if (entered[0] != 0){ //if it is not a zero, i.e. it has already been inputted
checkEntered2(button); //move on to checkEntered2, passing it "button"
else if(entered[0] == 0){ //if it is zero, i.e. if it hasn't been defined with a button yet
entered[0] = button; //set the first element as the button that has been pressed
Serial.print("1: ");Serial.println(entered[0]); //for debugging
void checkEntered2(int button){ //check the second element of the entered[] array
if (entered[1] != 0){ //if it is not a zero, i.e. it has already been inputted
checkEntered3(button); //move on to checkEntered3, passing it "button"
else if(entered[1] == 0){ //if it is zero, i.e. if it hasn't been defined with a button yet
entered[1] = button; //set the second element as the button that has been pressed
Serial.print("2: ");Serial.println(entered[1]); //for debugging
void checkEntered3(int button){ //check the third element of the entered[] array
if (entered[2] != 0){ //if it is not a zero, i.e. it has already been inputted
checkEntered4(button); //move on to checkEntered4, passing it "button"
else if (entered[2] == 0){ //if it is zero, i.e. if it hasn't been defined with a button yet
entered[2] = button; //set the third element as the button that has been pressed
Serial.print("3: ");Serial.println(entered[2]); //for debugging
void checkEntered4(int button){ //check the third element of the entered[] array
if (entered[3] != 0){ //if it is not a zero, i.e. it has already been inputted
checkEntered5(button); //move on to checkEntered4, passing it "button"
else if (entered[3] == 0){ //if it is zero, i.e. if it hasn't been defined with a button yet
entered[3] = button; //set the third element as the button that has been pressed
Serial.print("4: ");Serial.println(entered[3]); //for debugging
void checkEntered5(int button){ //check the third element of the entered[] array
if (entered[4] != 0){ //if it is not a zero, i.e. it has already been inputted
checkEntered6(button); //move on to checkEntered4, passing it "button"
else if (entered[4] == 0){ //if it is zero, i.e. if it hasn't been defined with a button yet
entered[4] = button; //set the third element as the button that has been pressed
Serial.print("5: ");Serial.println(entered[4]); //for debugging
void checkEntered6(int button){ //check the fourth element of the entered[] array
if (entered[5] == 0){ //if it is zero, i.e. if it hasn't been defined with a button yet
entered[5] = button; //set the final element as the button that has been pressed
Serial.print("6: ");Serial.println(entered[5]); //for debugging
delay(100); //allow time for processing
compareCode(); //call the compareCode function
void compareCode(){ //checks if the code entered is correct by comparing the code[] array with the entered[] array
for (int i = 0; i<6;i++){ //these three lines are for debugging
if ((entered[0]==code[0]) && (entered[1]==code[1]) && (entered[2]==code[2]) && (entered[3]==code[3]) && (entered[4]==code[4])&& (entered[5]==code[5])){ //if all the elements of each array are equal
digitalWrite(greenLed, HIGH); //turn the green LED on
delay(100000); //wait for a bit
digitalWrite(greenLed, LOW); //turn the green LED off
for (int i = 0; i < 7; i++){ //this next loop is for debugging
entered[i] = 0;
loop(); //return to loop() (not really necessary)
else { //if you (or the intruder) get the code wrong
Serial.println("Red OFF");
entered[i] = 0;
close_all();
void close_all(){
//digitalWrite(LED[0],LOW);
//digitalWrite(LED[1],LOW);
//digitalWrite(LED[2],LOW);
//digitalWrite(LED[3],LOW);
//digitalWrite(LED[4],LOW);
//digitalWrite(LED[5],LOW);
Yea i am getting rid of the delay. Do I just basically repeat all my code with a different combination to turn the greenLed to low state? I want to just hit the button 1 three times to turn greenLed low
Im already pressing the sequence to turn it ON im asking how to press a different sequence to turn it OFF!! Do I just repeat my code over again at the bottom?
Before adding extra functionality, you should improve your code...
Otherwise you will need to change things twice.
You should not leave a function by calling loop().
You should use return.
Using a for loop will save a lot of code...
When you have three or more variables with the same name except for a trailing number, make them an array.
const int ButtonCount = 6;
const byte ButtonPins[ButtonCount] = {2, 3, 4, 5, 6, 7}; //first button is on pin 2
int TurnOnCode[] = {6, 5, 5, 4, 3, 2};
const int TurnOnCodeCount = sizeof TurnOnCode / sizeof TurnOnCode[0];
int TurnOnCorrectCount = 0; // How many have been entered
int TurnOffCode[] = {6, 4, 2};
const int TurnOffCodeCount = sizeof TurnOffCode / sizeof TurnOffCode[0];
int TurnOffCorrectCount = 0; // How many have been entered
void setup() //run once at sketch startup
for (int i = 0; i < ButtonCount; i++)
pinMode(ButtonPins[i], INPUT_PULLUP);
Serial.print("Turn On code: ");
for (int i = 0; i < TurnOnCodeCount; i++)
Serial.print(TurnOnCode[i]); //print each digit of the code
Serial.print("Turn Off code: ");
for (int i = 0; i < TurnOffCodeCount; i++)
Serial.print(TurnOffCode[i]); //print each digit of the code
void loop() //run repeatedly
// Check each button
if (digitalRead(ButtonPins[i]) == LOW) //if button is pressed
// Button is pressed
checkEntered(i + 1); //call checkEntered and pass it the button number
delay(250); //wait, needed for correct functioning, otherwise
void checkEntered(int button) //check the button press
// Check against turn-on code
if (button == TurnOnCode[TurnOnCorrectCount])
TurnOnCorrectCount++;
if (TurnOnCorrectCount == TurnOnCodeCount)
// Success!
// Start over
else // Not the correct button
TurnOnCorrectCount = 0; // Start over
// Check against turn-off code
if (button == TurnOffCode[TurnOffCorrectCount])
TurnOffCorrectCount++;
if (TurnOffCorrectCount == TurnOffCodeCount)
// Success!
// Start over
TurnOffCorrectCount = 0; // Start over
If you do not understand what is in the posts, you may ask for explanation. For us (helpers) it is sometimes difficult to estimate how much a beginner we are dealing with.
Also it is sometimes difficult to derive what you actually try to achieve... that is why some ask a lot of questions...
If I understand what the OP trying to do. A numerical ( keypad) entry system by entering a 4 digit number to turn on a led ( could be a relay / selenoid lock ) and another 4 digit to turn off led ( relay / selenoid lock )
close what I am doing is enter a 6 digit code to turn the LED on and a 3 digit code to turn the led off, its for a custom gun safe im building and using an access control power supply and a electromagnetic lock with a battery backup
PS ... Separated the ammo for the weapon / guns for a better safety. Make sure the weapons are unloaded. In Canada ( where I live ) , they are illegal. Just my opinion.
@guix yea thats clean looking too thanks, I would just change the builtin LED to a pin to activate a 5v relay on my access control box and would work perfect, thanks
