HELP me with a code for LED and BUTTON
 void setup(){
   pinMode(8, INPUT);
   pinMode(13,OUTPUT);
 void loop(){
   if( digitalRead(8) == 1 ){
     digitalWrite(13, HIGH);
   else {
   digitalWrite(13, LOW);
The code above switches the LED on pin 13 ON when the button on pin 8 is pressed, and goes OFF when the button is released..
I want the button to be kept pressed for a long time, but the LED should go OFF after say 3 seconds though the button is kept pressed.
The same thing should happen every time the button is kept pressed for a long time..
As always, take a look at the blink without delay example.
You'll have to keep the pressed/released time somewhere then use it to turn the LED ON or OFF.
AWOL:
I can get this code to work..
int count =0;
 void setup(){
   pinMode(8, INPUT);
   pinMode(13,OUTPUT);
 void loop(){
   count = millis();
   if( digitalRead(8) == 1 && count <= 3000 ){
   else {
But how do I reset the count, so that the next time I press the button the count starts from 0...??
see below code..
unsigned long int count =0;
unsigned long int prevTime = 0;
 void setup(){
   pinMode(8, INPUT);
   pinMode(13,OUTPUT);
 void loop(){
   count = millis();
   if(/* digitalRead(8) == 1 &&*/ (count - prevTime <= 3000) ){
     Serial.println("Less than 3 Sec");
   else {
   prevTime = count;
  Serial.println("More than 3 Sec");
    delay(1000); // to check only
Using the TIme library found here : Time Library, Timekeeping and Time/Date Manipulation on Teensy
Use millis() if you don't want to rely on a 3rd party lib.
#include <Time.h>
#define DEBUG
byte inPin  = 8;
byte outPin = 13;
int pressed_time = 0;
int released_time= 0;
int timeout = 3; // Timeout after 3seconds
 void setup(){
   pinMode(inPin, INPUT);
   pinMode(outPin,OUTPUT);
   #ifdef DEBUG
   #endif
 void loop(){
   if(digitalRead(inPin) == HIGH)      // is our input pin HIGH ?
     pressed_time = now();              // Store the pressed time if HIGH
     #ifdef DEBUG
     Serial.println("Pressed");
     #endif
     digitalWrite(outPin, HIGH);        // HIGH the LED pin
   else                              // Our pin is LOW
     released_time = now();            // Store the released time
     if((pressed_time + timeout) > released_time)  // Checks if the pressed time + 3second is more than the released time; Don't do anything to the LED if it is.
       #ifdef DEBUG
       int dif = (pressed_time + timeout) - released_time;
       Serial.print("Not Pressed but we keep running for:");
       Serial.println(dif);
       #endif
     else                                  // It is not anymore, turn the LED pin LOW
       #ifdef DEBUG
       Serial.println("Not Pressed and timed out.");
       #endif
       digitalWrite(outPin, LOW);
   #ifdef DEBUG
   delay(100); // debug
   #endif
you don't need to use a library with your requirements... plus you should invest the time into learning BlinkWithoutDelay, as AWOL suggested.
try something like this...
int ledPin = 13;
int buttonPin = 8;
int lastState;
boolean ledState = false;
unsigned long ledStartTime;
  pinMode(buttonPin, INPUT);
  pinMode(ledPin,OUTPUT);
  int buttonState = digitalRead(buttonPin);
  if (buttonState != lastState && ledState == false)
    Serial.println(buttonState? "HIGH" : "LOW");
    ledStartTime = millis();
    ledState = true;
  lastState = buttonState;
  if (ledState == true)
    if (millis() - ledStartTime <= 3000UL)
      digitalWrite(ledPin, HIGH);
      digitalWrite(ledPin, LOW);
      ledState = false;
{return(loop());}
WTF?
The loop() function does not return a value. The function that this statement is in does not return a value.
You should NOT be calling loop() from this function.
for a random period of time (between 3 & 7 seconds)
 delay (7000);
Nothing random about that delay!
 if (digitalRead(ledPin)==HIGH  )
You just made the pin HIGH. How is the if statement EVER going to not be true, unless you've toasted the hardware? If you have, does the rest of the code matter?
      start = millis();
      delay(200);
      Serial.println("Started...");
Be sure that you deduct this wasted time from the reaction time.
if( digitalRead(buttonPin) == LOW )
That is NOT waiting for the pin to go LOW.
Hi Paul from Seattle thanks a lot for answering... :slight_smile:
Here in this forum seems to be lost in the ocean...and nobody can save you...anyway the problem should be solved with while () ; (waiting for the button to be pushed) and without if...I am writing from my phone so it is difficult to explain...return loop doesn't create confusion...bye cheers!!!!
belinda:
No, not much.
OK to avoid risks I have cancelled it now thanks
