Help me with code2
hi.
how can i use 2 codes combined .
Line Tracking Robot and 8*16 LED Board
unsigned char start01[] = {0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80,0x80,0x40,0x20,0x10,0x08,0x04,0x02,0x01};
unsigned char front[] = {0x00,0x00,0x00,0x00,0x00,0x24,0x12,0x09,0x12,0x24,0x00,0x00,0x00,0x00,0x00,0x00};
unsigned char back[] = {0x00,0x00,0x00,0x00,0x00,0x24,0x48,0x90,0x48,0x24,0x00,0x00,0x00,0x00,0x00,0x00};
unsigned char left[] = {0x00,0x00,0x00,0x00,0x00,0x00,0x44,0x28,0x10,0x44,0x28,0x10,0x44,0x28,0x10,0x00};
unsigned char right[] = {0x00,0x10,0x28,0x44,0x10,0x28,0x44,0x10,0x28,0x44,0x00,0x00,0x00,0x00,0x00,0x00};
unsigned char STOP01[] = {0x2E,0x2A,0x3A,0x00,0x02,0x3E,0x02,0x00,0x3E,0x22,0x3E,0x00,0x3E,0x0A,0x0E,0x00};
unsigned char clear[] = {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
#define SCL_Pin A5 //Set clock pin to A5
#define SDA_Pin A4 //Set data pin to A4
void setup(){
//Set pin to output
pinMode(SCL_Pin,OUTPUT);
pinMode(SDA_Pin,OUTPUT);
//Clear the matrix display
matrix_display(clear);
void loop(){
matrix_display(start01); //Display start pattern
delay(2000);
matrix_display(front); ///Front pattern
delay(2000);
matrix_display(STOP01); //Stop pattern
delay(2000);
matrix_display(clear); //Clear the matrix display
delay(2000);
//this function is used for dot matrix display
void matrix_display(unsigned char matrix_value[ ])
IIC_start(); //the function to call the data transmission
IIC_send(0xc0); //Select address
for(int i = 0;i < 16;i++) //Pattern data has 16 bytes
IIC_send(matrix_value[i]); //data to convey patterns
IIC_end(); //end the transmission of patterns data
IIC_start();
IIC_send(0x8A); //display control, set pulse width to 4/16
IIC_end();
// the condition that data transmission starts
void IIC_start()
digitalWrite(SCL_Pin,HIGH);
delayMicroseconds(3);
digitalWrite(SDA_Pin,HIGH);
digitalWrite(SDA_Pin,LOW);
// transmit data
void IIC_send(unsigned char send_data)
for(char i = 0;i < 8;i++) //Every character has 8 bits
digitalWrite(SCL_Pin,LOW); //pull down the SCL_Pin to change the signal of SDA
if(send_data & 0x01) //1 or 0 of byte is used to set high and low level of SDA_Pin
digitalWrite(SCL_Pin,HIGH); //Pull up SCL_Pin to stop data transmission
send_data = send_data >> 1; //Detect bit by bit, so move the data right by one bit
//the sign that data transmission ends
void IIC_end()
#define ML_Ctrl 4 //define direction control pin of B motor
#define ML_PWM 5 //define PWM control pin of B motor
#define MR_Ctrl 2 //define direction control pin of A motor
#define MR_PWM 9 //define PWM control pin of A motor
const int sensor_l = 6;//define the pin of left line tracking sensor
const int sensor_c = 7;//define the pin of middle line tracking sensor
const int sensor_r = 8;//define the pin of right line tracking sensor
int l_val,c_val,r_val;//define these variables
Serial.begin(9600);//start serial monitor and set baud rate to 9600
pinMode(ML_Ctrl, OUTPUT);//set direction control pin of B motor
pinMode(ML_PWM, OUTPUT);//set PWM control pin of B motor to OUTPUT
pinMode(MR_Ctrl, OUTPUT);//set direction control pin of A motor to OUTPUT
pinMode(MR_PWM, OUTPUT);//set PWM control pin of A motor to OUTPUT
pinMode(sensor_l,INPUT);//set the pins of left line tracking sensor to INPUT
pinMode(sensor_c,INPUT);//set the pins of middle line tracking sensor to INPUT
pinMode(sensor_r,INPUT);//set the pins of right line tracking sensor to INPUT
tracking(); //run main program
void tracking()
l_val = digitalRead(sensor_l);//read the value of left line tracking sensor
c_val = digitalRead(sensor_c);//read the value of middle line tracking sensor
r_val = digitalRead(sensor_r);//read the value of right line tracking sensor
if(c_val == 1)//if the state of middle one is 1, which means detecting black line
front();//car goes forward
if((l_val == 1)&&(r_val == 0))//if only left line tracking sensor detects black trace
left();//car turns left
else if((l_val == 0)&&(r_val == 1))//if only right line tracking sensor detects black trace
right();//car turns right
else// if left and right line tracking sensors detect black trace or they don’t read
Stop();//car stops
void front()//define the status of going forward
digitalWrite(ML_Ctrl,HIGH);//set direction control pin of B motor to HIGH
analogWrite(ML_PWM,70);//set PWM control speed of B motor to 70
digitalWrite(MR_Ctrl,HIGH);//set direction control pin of A motor to HIGH
analogWrite(MR_PWM,70);//set PWM control speed of A motor to 70
void back()//define the state of going back
digitalWrite(ML_Ctrl,LOW);//set direction control pin of B motor to LOW
analogWrite(ML_PWM,200);//set PWM control speed of B motor to 200
digitalWrite(MR_Ctrl,LOW);//set direction control pin of A motor to LOW
analogWrite(MR_PWM,200);//set PWM control speed of A motor to 200
void left()//car turns left
digitalWrite(MR_Ctrl,HIGH);//set direction control pin of A motor to HIGH level
void right()//define the right-turning state
digitalWrite(ML_Ctrl,HIGH);//set direction control pin of B motor to HIGH level
void Stop()//define the state of stop
analogWrite(ML_PWM,0);//set PWM control speed of B motor to 0
analogWrite(MR_PWM,0);//set PWM control speed of A motor to 0
You could start with this tutorial.
Post you code in tags - these things </> in the editor.
What have you tried so far?
Start by posting the code correctly to make it easy to read
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
void setup(){
  //Set pin to output
void loop(){
  delay(2000);
  delay(2000);
  delay(2000);
  delay(2000);
void matrix_display(unsigned char matrix_value[])
  IIC_start();
  IIC_end();
void IIC_start()
// transmit data
void IIC_end()
and
void tracking()
      Stop();//car stops
Thanks.. now we can see the code.
So what have you tried so far? What are you having trouble with?
I can't write 2 codes together
Most of the people here aren't interested in doing the work for you. If you demonstrate you have tried, and are still stuck - then you will get a lot more support.
But you need to at least try...
Please describe what each sketch does, what the combined sketch should do and post your best effort at a combined sketch and describe the problems encountered
  //Set pin to output
  delay(2000);
  delay(2000);
  delay(2000);
  delay(2000);
void tracking()
    front5();//car goes forward
      left5();//car turns left
      right5();//car turns right
      Stop();//car stops
void front5()//define the status of going forward
void back5()//define the state of going back
void left5()//car turns left
void right5()//define the right-turning state
  IIC_start();
  IIC_end();
void IIC_start()
// transmit data
void IIC_end()
I have tried this form but it does not work
only moves in a straight line when merging.
Follow the line I need and write on the led panel.
@elvin_melik we need more information... as per the request from @UKHeliBob
The more detail the better... you will get a lot more help if you provide more information.
What does that mean?
I want both the LED panel to write and the robot to move
Have you tried printing the values read by the sensors in the tracking() function ? What do they show ?
