Help me with my code, double loop if possible
I am using arduino UNO v3, my code should do the following, read 10 sensor values, make an average, turn one of the 3 leds according to the value. The average sum should be displayed once per second so that means I need to read the input value once every 0.1 seconds.
Before using the double loop, the min value was 0 and max value was around 600, using the double loop the read value from the sensor has gone haywire
later edit: for the simulation of the sensor, i am using a potentiometer
int leda = 2;
int ledb = 4;
int ledc = 6;
pinMode(leda, OUTPUT);
pinMode(ledb, OUTPUT);
pinMode(ledc, OUTPUT);
int a;
int v[10], i, s=0, j;
double m;
for (j=0; j < 10 ; j++){
Serial.println(j);
delay(100);
for (i=1; i<=10; i++)
{a = analogRead(A0);
v = a;
s=s+v*;*
m=s/10;
Serial.println(m);
* if (m < 200 )*
* digitalWrite(leda, HIGH);*
* digitalWrite(ledb, LOW);*
* digitalWrite(ledc, LOW);*
else if (m > 400 )
* digitalWrite(leda, LOW);*
* digitalWrite(ledc, HIGH);*
* else*
* digitalWrite(ledb, HIGH);*
* Serial.println(a);*
* Serial.println(m);*
* delay(1000);*
Just taking a cursory look at it, shouldn't:
m=s/10;
Be more like
m=s/100;
Because you are averaging 100 samples since it's in an embedded loop.
But, I bet your problem is that you're blowing through the 32,767 limit of an int (variable "s"). Try making it a "long", and see if that helps.
Use code tags when posting. If you don’t know how, take a look at the How to use this Forum thread at the top of these forums.
Hi…try this…
v = a;
s=s+v;
m=s/10;
Serial.println(m);
I think you are not averaging and serial sending in the right place.
My 10cents worth… Tom
emil_irimia:
The code you have posted does not do what the above description says. Why do you need a double loop at all?
Your code is taking one hundred sensor readings, in groups of 10. It then divides the sum by ten. I don’t think this is what you want. Also you are really mis-using the variable v.
It is an array, and you should use a sub-script when assigning elements to it.
   v[j] = a;
Do you mean the actual values from analogRead are now bad, or the “average”?
A much simpler thing to do:
    long sum;
    int reading, avg;
    for (int i = 0; i < 10; i++)
        reading = analogRead(A0);
        sum += reading;
    avg = reading / 10;
    Serial.println(avg);
    delay(900);  /* most of a second. */
Please use code tags, like this:
int leda = 2;
int ledb = 4;
int ledc = 6;
int a;
double m;
Serial.println(j);
delay(100);
v[i] = a;
s=s+v[i];
m=s/10;
Serial.println(m);
if (m < 200 )
else if (m > 400 )
  Serial.println(a);
  Serial.println(m);
