Help me with the code UNO RELAY LCD LED LAMP
UnoDHT11RelayDisplay16x2 Led lamps №2.ino (1.5 КБ)
This comes out when uploading the code can you me help
You did something wrong in the code you didn't post.
The code is posted in the article
No, it isn't posted.
I wouldn't have commented if it had been.
Please post it like this.
#include <DHT.h>
#define DHTPIN 3
#define DHTTYPE DHT11
#define WHITE_LED 5  // pin to which white LED is connected
#define GREEN_LED 6  // pin to which green LED is connected
#define RED_LED 7  // pin to which red LED is connected
LiquidCrystal_I2C lcd (0x27, 20, 3);
DHT dht (DHTPIN, DHTTYPE);
  pinMode(12, OUTPUT);
  pinMode(11, OUTPUT);
  pinMode(WHITE_LED, OUTPUT);
  pinMode(GREEN_LED, OUTPUT);
  pinMode(RED_LED, OUTPUT);
  dht.begin();
  lcd.init();
  lcd.setCursor(0, 0);
  lcd.backlight();
  lcd.print ("Starting LCD...");
  delay (1000);
  lcd.clear();
  lcd.setCursor (0, 0);
  lcd.print ("Temp.: ");
  lcd.print (int(dht.readTemperature()));
  lcd.print (" \337C");
  lcd.setCursor (0, 1);
  lcd.print ("Humidity: ");
  lcd.print (int(dht.readHumidity()));
  lcd.print ("%");
  delay (100);
  if (int(dht.readTemperature()) <= 27) {
    digitalWrite(12, HIGH);
    digitalWrite(11, LOW);
  } if (int(dht.readTemperature()) > 27) {
    digitalWrite(12, LOW);
    digitalWrite(11, HIGH);
  If (Temp < 20) {
    digitalWrite(WHITE_LED, HIGH);
    digitalWrite(GREEN_LED, LOW);
    digitalWrite(RED_LED, LOW);
  } if (Temp > 20 & temp. < 30) {
    digitalWrite(WHITE_LED, LOW);
    digitalWrite(GREEN_LED, HIGH);
  } If(Temp > 30) {
    digitalWrite(RED_LED, HIGH);
  delay(2000);
Maybe this part?
If(Temp > 30) {
The IF statement is capitalized
if (Temp > 30) {
Yes
I rewrote the if statements and removed the extra } at the end of the code. You don't have a DHT.h file attached so fix that and continue.
#include <DHT.h>
#define DHTPIN 3
  dht.begin();
  lcd.init();
  lcd.backlight();
  delay (1000);
  lcd.clear();
  lcd.print ("%");
  delay (100);
  if (Temp < 20) {
  if (Temp > 30) {
  delay(2000);
This is coming out
Do you have the DHT.h file included in your sketch?
I think so
You didn't in the .ino file you attached so I don't think you do. Or maybe it's in a library you don't have. I don't know. You need to go back to the display provider and make sure you have all the correct libraries and code you need.
#include <DHT.h>
#define DHTPIN 3
dht.begin();
lcd.init();
lcd.setCursor(0,0);
lcd.backlight();
delay (1000);
lcd.clear();
lcd.setCursor (0,0);
lcd.setCursor (0,1);
lcd.print ("%");
delay (100);
if (int(dht.readTemperature()) <=27){
digitalWrite(12,HIGH);
digitalWrite(11,LOW);
}if (int(dht.readTemperature()) >27){
digitalWrite(12,LOW);
digitalWrite(11,HIGH);
This code is tried and tested, I just add a few things
#include <DHT.h>
#define DHTPIN 3
  dht.begin();
lcd.init();
lcd.setCursor(0,0);
lcd.backlight();
delay (1000);
lcd.clear();
lcd.print ("%");
delay (100);
If (Temp < 20){
  }if (Temp > 20 & temp. < 30) {
  }If(Temp > 30) {
  delay(2000);
Still have the capitalized 'I'.
Two Three problems there, I feel.
  • two variables not declared or different written
  • using bitwise AND-operator instead of logical AND-operator
  • adding a dot behind a simple variable which would guide into a struct that is not defined and not named
Take a look into this tutorial:
Arduino Programming Course
It is easy to understand and has a good mixture between explaining important concepts and example-codes to get you going. So give it a try and report your opinion about this tutorial.
best regards Stefan
Oops - yes, I missed the single '&' (though it ought to have worked as expected)
