help:merging 2 examples
I’d like to preclude that I’m rather new to the Arduino software, so I’m sorry if this is a simple question. I’ve found two example sketches that when put together would work well with what I’m trying to do. One of the examples is the RGB fader with potentiometer, and the other is a standard servo control with potentiometer. I tried my best to get them to work together but I’m still having trouble.
Here’s the RGB fader code:
* Code for making one potentiometer control 3 LEDs, red, grn and blu, or one tri-color LED
* The program cross-fades from red to grn, grn to blu, and blu to red
* Debugging code assumes Arduino 0004, as it uses Serial.begin()-style functions
* Clay Shirky <clay.shirky@nyu.edu>
// INPUT: Potentiometer should be connected to 5V and GND
int potPin = 3; // Potentiometer output connected to analog pin 3
int potVal = 0; // Variable to store the input from the potentiometer
// OUTPUT: Use digital pins 9-11, the Pulse-width Modulation (PWM) pins
// LED's cathodes should be connected to digital GND
int redPin = 9;   // Red LED,   connected to digital pin 9
int grnPin = 10;  // Green LED, connected to digital pin 10
int bluPin = 11;  // Blue LED,  connected to digital pin 11
// Program variables
int redVal = 0;   // Variables to store the values to send to the pins
int grnVal = 0;
int bluVal = 0;
int DEBUG = 1;          // Set to 1 to turn on debugging output
  pinMode(redPin, OUTPUT);   // sets the pins as output
  pinMode(grnPin, OUTPUT);
  pinMode(bluPin, OUTPUT);
  if (DEBUG) {           // If we want to see the pin values for debugging...
    Serial.begin(9600);  // ...set up the serial ouput in 0004 format
// Main program
  potVal = analogRead(potPin);   // read the potentiometer value at the input pin
  if (potVal < 341)  // Lowest third of the potentiometer's range (0-340)
    potVal = (potVal * 3) / 4; // Normalize to 0-255
    redVal = 256 - potVal;  // Red from full to off
    grnVal = potVal;        // Green from off to full
    bluVal = 1;             // Blue off
  else if (potVal < 682) // Middle third of potentiometer's range (341-681)
    potVal = ( (potVal-341) * 3) / 4; // Normalize to 0-255
    redVal = 1;            // Red off
    grnVal = 256 - potVal; // Green from full to off
    bluVal = potVal;       // Blue from off to full
  else  // Upper third of potentiometer"s range (682-1023)
    potVal = ( (potVal-683) * 3) / 4; // Normalize to 0-255
    redVal = potVal;       // Red from off to full
    grnVal = 1;            // Green off
    bluVal = 256 - potVal; // Blue from full to off
  analogWrite(redPin, redVal);   // Write values to LED pins
  analogWrite(grnPin, grnVal);
  analogWrite(bluPin, bluVal);
  if (DEBUG) { // If we want to read the output
    DEBUG += 1;      // Increment the DEBUG counter
    if (DEBUG > 100) // Print every hundred loops
      DEBUG = 1;     // Reset the counter
                             // Serial output using 0004-style functions
      Serial.print("R:");    // Indicate that output is red value
      Serial.print(redVal);  // Print red value
      Serial.print("\t");    // Print a tab
      Serial.print("G:");    // Repeat for grn and blu...
      Serial.print(grnVal);
      Serial.print("\t");
      Serial.print("B:");
      Serial.println(bluVal); // println, to end with a carriage return
and here is the servo control code:
// Controlling a servo position using a potentiometer (variable resistor)
// by Michal Rinott <http://people.interaction-ivrea.it/m.rinott>
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
int potpin = 0;  // analog pin used to connect the potentiometer
int val;    // variable to read the value from the analog pin
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  val = analogRead(potpin);            // reads the value of the potentiometer (value between 0 and 1023)
  val = map(val, 0, 1023, 0, 179);     // scale it to use it with the servo (value between 0 and 180)
  myservo.write(val);                  // sets the servo position according to the scaled value
  delay(15);                           // waits for the servo to get there
And this is the merged code I ended up with:
#include <Servo.h>
int grnVal = 0;
int bluVal = 0;
  myservo.attach(3);  // attaches the servo on pin 3 to the servo object
// Main program
  potVal = map(potVal, 0, 1023, 0, 179);     // scale it to use it with the servo (value between 0 and 180)
  myservo.write(potVal);                  // sets the servo position according to the scaled value
  delay(15);
      Serial.print("\t");
      Serial.print("B:");
Basically, I replaced the int “val” from the servo sketch with “potVal” to match the RGB code, and in the same manner replaced “potpin” with “potPin”. The rest was just placed into the designated areas. With this code, the LED Fader still works, but the Servo doesn’t move. If anyone sees the problem with my code, or knows of a solution, I could really use the help. Thanks in advance.
You can't use pin 3 for a servo. Check the documentation for the library. http://arduino.cc/en/Reference/Servo
potVal = map(potVal, 0, 1023, 0, 179); // scale it to use it with the servo (value between 0 and 180) myservo.write(potVal); // sets the servo position according to the scaled value delay(15);
Odd way of doing things - you're relying on the initial value of potVal, and then the value from the last time through "loop", which anyway was normalised to 0..255. Why not read "potVal" first?
myservo.write(map (potVal, 0, 1023, 0, 179));                  // sets the servo position according to the scaled value
  delay(15);
