Good morning,
I've a problem, my arduino mkr wan 1300 has the architecture samd, and i need a library that can let it works with the architecture mfrc522, do you know any libraries to make this two architecture works?
Good morning,
mfrc522 is NOT an architecture.
My bad sorry, but there is a library that can works with the mkr wan 1300?
What do you expect the library to do?
I want that the sensor rfid works with the mkr wan 1300, without problems
MG95:
So, get busy writing such a library. Or, use an Arduino that the existing library is designed to work with.
follow the getting started link then Use your Arduino MKR WAN 1300 on the Arduino Web IDE then MKRWANLoraSendAndReceive
Hello friends. I need help on a topic. I bought some Arduino MKR 1300 and I have not been able to connect them to the Lora network. I have tried via OTTA and it appears to me that I should be closer to the window. I’m new to IoT, I’d like you to help me a bit with this. What happens if I do not join the network, could I also communicate two MKR nodes without the need to join the Lora network?
I have been guiding myself through this page: https://github.com/gonzalocasas/arduino-mkr-wan-1300
Please help me !!
Check with the Things map if you have a Lora Gateway nearby
reception can be effected by buildings, hills, trees, etc between you and the gateway and also the construction of the building you are in - moving the MKR 1300 near to a window may help
if that fails you could set up your own gateway
communication between two MKR 1300 devices should be possible using peer-to-peer communication - I have done this with Arduino Lorashield, Adafruit feather 32u4 and Microchip PicTail Lora devices in addition to connecting to the LoraWAN network using OTTA
