[HELP] Mkr Wan
Hello,
im university student, and i've project with them, i've to pair up an arduino mkr wan 1300 with some sensor, but i've never used arduino in my life, so i dont know how i can know if a sensor is compatible with the mkr wan, i need one rfid sensor, and 2 random sensor (like temperature and movement), if anyone know sensor that are 100% compatible link me i'll appreciate that, otherwise tell me how i can know if a sensor can be compatible.
Thank you, and have a nice day.
Almost all sensors are comparable with an Arduino. The only ones that are not have a USB output designed to be plugged into a computer. Even those can be used with a USB host shield and the right software which is often where the difficulty is.
Basically a sensor needs to have an output voltage between zero and five volts and connects to the analogue input and ground. If it has a larger or smaller output then you might need a component or two to make the output into the range the Arduino likes.
Grumpy_Mike:
Basically a sensor needs to have an output voltage between zero and five volts...
Not for this one though.
The MKR WAN 1300 is based on the Atmel SAMD21 chip.
Needs AFAIK 3.3volt sensors/data.
Leo..
So for example if I bought a kit including sensors, cables and resistors I could use the resists to reduce the voltage to 3.3v and use these sensors?
I leave a link to the kit that I wanted to buy sorry but it is in my native language.
Only if the kit contained the right values of resistors.
You would have to look at each sensor individually to see what was needed to use it with your 3V3 system.
That means horror of horrors, you might have to actually understand things.
I've one last question, do you know if i plug in the mkr wan inside a breadborard and if i feed the mkr wan with 5v, because it can takes that voltage by the usb port, can i power up a sensor connected to the board?.
If you connect the 5V to the Vin pin then yes you can.
You can not use just resistors to change a power supply voltage. You need one or more of regulators, buck converters, switching power supplies, transformers, etc. All depending on what you want to power.
There are lots of RFID sensors, a huge number of temperature sensors (with varying temperature ranges, accuracies, price points, etc), and motion sensors possibly even more considering the great number of different forms of motion there are and the different ways of sensing them.
