help MsTimer2
When I try to use MsTimer2 it says:
"projetTickTock2.0:6: error: 'namespaceMsTimer2' does not name a type
void flash(){
exit status 1
'namespaceMsTimer2' does not name a type"
This is the code I get the error: "
#include <MsTimer2.h>
#define LED 13
void flash(){
static boolean output = HIGH;
digitalWrite(LED, OUTPUT);
output = !output;
pinMode(13, OUTPUT);
MsTimer2::set(500, flash);
MsTimer2::start();
Thanks
And where did you get the MsTimer2 library?
static boolean output = HIGH;Not the cause of your problem but why boolean/HIGH rather than byte/HIGH or boolean/true ?
Do you actually have a variable named OUTPUT ?
Try making an instance of MsTimer instead of calling the class methods directly with ::
MsTimer2 indicator;
indicator.set(500, flash);
  indicator.start();
