Help! My continuous rotation servo does not seem to be working properly!
When I call the function servo.read() it returns 180, but the servo is not rotating!
The code is here:
#include <Servo.h>
#include <Wire.h>
#include "SparkFunMPL3115A2.h"
//Create an instance of the object
MPL3115A2 myPressure;
Servo myservo;  // create servo object to control a servo
// twelve servo objects can be created on most boards
int pos = 0; // variable to store the servo position
int isFalling = 0; //should be equal to zero dont forget to change it back
int maxAlt = 0;
  myservo.attach(0);// attaches the servo on pin 0 to the servo object
  myservo.write(90);
  Wire.begin();        // Join i2c bus
  Serial.begin(9600);  // Start serial for output
  myPressure.begin(); // Get sensor online
  //Configure the sensor
  myPressure.setModeAltimeter(); // Measure altitude above sea level in meters
  //myPressure.setModeBarometer(); // Measure pressure in Pascals from 20 to 110 kPa
  myPressure.setOversampleRate(7); // Set Oversample to the recommended 128
  myPressure.enableEventFlags(); // Enable all three pressure and temp event flags
  float alt = myPressure.readAltitudeFt();
  //float alt = Serial.read();
//  Serial.print(" Altitude(ft):");
//  Serial.println(alt, 2);
//  Serial.println(maxAlt);
//  Serial.println(myservo.read());
//  delay(150);
  if(alt>maxAlt)
    maxAlt = alt;
  if(alt<(maxAlt-10) && isFalling==0 && maxAlt!=0)
    isFalling = 1;
  if(isFalling == 1)
    myservo.write(180);
    delay(150);
    isFalling = 2;
And this is an image of how I have it physically hooked up:
  myservo.write(90);
What is wrong with this picture?
I don't know, I'm very new to Arduino.
Look carefully at the label next to pin zero on the board.
TolpuddleSartre:
Oh, I’m an idiot… thank you for letting me know :stuck_out_tongue:
