(Help)My Ethernet Shield suddenly stopped working (Solved)
Hi to everyone, thanks for reading.
I've recieved my ethernet shield and it was working OK (without making portforwarding on the modem/router because I can't access it) but it was working ok with the example codes. But after I connected a Protoshield (with no components), then it just stopped working, I can't get any example to work. The protoshield doesn't fits very well upside the ethernet because it touches the RJ45 connecter, but I've put some protective tape there before connecting anything to avoid contact between the two shields. :astonished: On the RJ45 connector of the ethernet shield I only see the green led ON but it never blinks, and the right led is always off. I don't remeber if this leds were working ok before connecting the protoshield. Is this led states normal? or are they showing that something is not working ok??
Thanks for any help! :|
You should post a link to the ethernet shield and the proto shield. You should also explain how they are connected. Which shield is connected to the Arduino? Which model Arduino do you have? Does it work ok by itself?
If you remove the protoshield, does the ethernet shield start working again?
SurferTim:
Hi, thanks for the answers!
I have a Wiznet w5100 and this protoshield:
I’ve attached a picture that show how they are connected and how the protoshield touch the RJ45 case (but I’ve checked and there is no risk when they touch each other, nothing is connected on the protoshield on that area) :fearful:
The Arduino UNO R3 works fine, but something curious happened. I was getting an error when uploading a skecth, and I’ve checked and in the IDE Tools->Board, the board was changed to Duemilanova… :fearful: I set it again to UNO and the error disappeared. Strange!
Another question… I know that my ports are closed, could that be the problem?? But its strange because it worked for a while
zoomkat:
Sadly no :(. It won’t work. I’ve changed the UTP cable, rebooted the modem, change the ip, the MAC, but nothing :frowning:
Thanks!!
Try this test code. It checks the SPI connection to the ethernet shield. If the IP shows in the serial monitor as 192.168.2.2, then that part is working. If it shows anything else, like 0.0.0.0, then that part is failing. Check the pins (especially the ICSP pins) to insure good contact with the Arduino.
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = {  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,2,2);
  // disable SD card if one in the slot
  pinMode(4,OUTPUT);
  digitalWrite(4,HIGH);
  Serial.println("Starting w5100");
  Ethernet.begin(mac,ip);
  Serial.println(Ethernet.localIP());
SurferTim:
#include <SPI.h>
byte mac = {  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
 pinMode(4,OUTPUT);
Serial.println(“Starting w5100”);
I can’t believe it, it’s working again!!! XD XD XD. I’ve tested your code, and it gave me 192.168.2.2, after that i’ve checked the ICSP connector but everything was OK, and magically it started working again!! I’m very happy ahah.
Thanks for your help!!
SurferTim:
#include <SPI.h>
  pinMode(4,OUTPUT);
I, too, have been having trouble with DHCPAddressPrinter sketch. I tried your example, above, and got it to print an IP address (one that I didn’t expect). Using that one for the DHCPAddressPrinter sketch doesn’t work. I did not have a MAC address for my board so I made one up. Can you suggest any ideas to try to get it to work? I am trying to get a WebServer online. Thanks.
What do you mean "one that I didn't expect"? If you want a simple web server sketch, then you can try mine in the playground. Use the second sketch near the bottom of this page. It is smaller than the new sketch. http://playground.arduino.cc/Code/WebServerST
I also got an IP address that I would not have expected: 211.166.43.52. My local router IP address is 192.168.0.1, I believe.
nkuck: I also got an IP address that I would not have expected: 211.166.43.52. My local router IP address is 192.168.0.1, I believe.
Does the shield have a w5100 network controller? It could also have a w5200 or enc28j60. Are the network leds on the front of the RJ45 connector lit? Does it always return that IP? Do you have a SD card in the shield's slot? Any other devices connected to your Arduino?
I found that my problem was with the Seeed ethernet shield. I have a V1.1 and a V2.2. Turns out that the sketch and Library I was using works with the older V1.1 board but not the newer V2.2. I tried installing the latest(?) libraries for V2.2 but can not get it to compile.
The V1 shield has a w5100 IC. That uses the standard ethernet library. Use this include for it.
The V2 shield has a w5200 IC, so it needs the Seeed library. Download and import this library using “Sketch/Import Library/Add Library”.
http://www.seeedstudio.com/wiki/Ethernet_Shield_V2.0
#include <EthernetV2_0.h>
