this is my whole code.
#include <SD.h>
#include <LiquidCrystal.h>
int CS_pin = 53;
volatile long lastSave = 0;
volatile long lcdTimeOut = 0;
volatile int saveInterval = 10;
volatile int lcdInterval= 60;
const int reps = 9;
LiquidCrystal lcd(8,3,4,5,6,7);
#define muxA0 15
#define muxA1 16
#define muxA2 17
#define tempPin 0
#define lcdLight 9
#define button1 2
int button1INT = 0;
#define aref_voltage 1.1
const int chs = 8;
const int numReadings = 10;
long tempInArray[numReadings][chs];
int index = 0;
long total[chs];
float averages[chs];
void error(char *str)
lcd.clear();
lcd.home();
lcd.print("error: ");
lcd.print(str);
while(1);
void setup(void)
analogReference(INTERNAL1V1);
pinMode(muxA2, OUTPUT);
pinMode(muxA1, OUTPUT);
pinMode(muxA0, OUTPUT);
pinMode(button1, INPUT);
digitalWrite(lcdLight, HIGH);
lcd.begin(20,4);
lcd.setCursor(0,0);
lcd.print("Tugas Akhir");
lcd.setCursor(0,1);
lcd.print("Miniatur Hujan Salju");
delay (5000);
lcd.clear();
lcd.setCursor(0,0);
lcd.print ("Oleh: ");
lcd.setCursor(0,1);
lcd.print ("Mochamad Rikki Firmansyah");
lcd.setCursor(0,2);
lcd.print ("dan");
lcd.setCursor(0,3);
lcd.print ("Ichsan T Primanizar");
delay (5000);
lcd.clear();
//initialize the SD card
if (!SD.begin(CS_pin))
lcd.setCursor(0,0);
lcd.println ("Card Failure ");
delay (3000);
lcd.clear();
return;
lcd.println ("Card Ready");
delay (3000);
lcd.clear();
File commandFile = SD.open ("COMMAND.txt");
if (commandFile)
lcd.setCursor(0,0);
lcd.println ("Membaca File");
delay (3000);
lcd.clear();
while (commandFile.available());
lcd.println ("File Tdk Trsedia");
delay (3000);
lcd.clear();
File logFile = SD.open ("LOG.csv", FILE_WRITE);
if (logFile)
logFile.println (", , , , , , , ,");
String header = "Ch1, Ch2, Ch3, Ch4, Ch5, Ch6, Ch7, Ch8";
logFile.println (header);
logFile.close();
lcd.setCursor (0,0);
lcd.print ("data failed");
delay (2000);
lcd.clear();
saveInterval = saveInt(); //call saveInt sub-function and return value
lcdInterval = lcdInt(); //call lcdInt sub-function and return value
for (int channel = 0; channel < chs; channel++) {
for (int i = 0; i < numReadings; i++) {
tempInArray[i][channel] = 0; //initialize all values to 0
void loop(void)
total[channel] = total[channel] - tempInArray[index][channel];
digitalWrite(muxA0, (channel & 1));
digitalWrite(muxA1, (channel & 2)>>1);
digitalWrite(muxA2, (channel & 4)>>2);
delay(5);
analogRead(tempPin);
delay(20);
tempInArray[index][channel] = analogRead(tempPin);
total[channel] = total[channel] + tempInArray[index][channel];
averages[channel] = total[channel] / numReadings;
averages[channel] = averages[channel] * aref_voltage / 1024;
averages[channel] = averages[channel] * 100;
index = index++;
if (index >= numReadings) {
index = 0;
lcd.home();
int row = 0;
for (int i = 0; i <=6; i = i + 2) {
lcd.setCursor(0,row);
lcd.print("Ch");
lcd.print(i+1);
lcd.print(":");
lcdPrintDouble(averages[i],1);
lcd.setCursor(10,row);
lcd.print("Ch");
lcd.print(i+2);
lcd.print(":");
lcdPrintDouble(averages[i+1],1);
row++; //increment row counter
int saveInt() {
int buttonValue1;
int buttonValue2;
int buttonState;
int minutes;
lcd.clear();
lcd.print("Choose save interval");
lcd.setCursor(0,1);
lcd.print(saveInterval);
lcd.setCursor(3,1);
lcd.print("seconds");
buttonState = digitalRead(button1);
buttonValue1 = digitalRead(button1);
delay(10);
buttonValue2 = digitalRead(button1);
if (buttonValue1 == buttonValue2) {
if (buttonValue1 != buttonState) {
if (buttonValue1 == LOW) {
if (saveInterval >= 5 && saveInterval < 20) {
saveInterval = saveInterval + 5; //set value to 5, 10, 15 or 20 seconds
} else if(saveInterval >= 20 && saveInterval < 30) {
saveInterval = saveInterval + 10; //set value to 30 seconds
} else if(saveInterval >= 30 && saveInterval < 60) {
saveInterval = saveInterval + 30; //set value to 60 seconds
} else if(saveInterval >= 60 && saveInterval < 120) {
saveInterval = saveInterval + 60; //set value to 120 seconds
} else if(saveInterval >= 120 && saveInterval < 300) {
saveInterval = saveInterval + 180; //set value to 5 minutes (300 seconds)
} else if(saveInterval >= 300 && saveInterval < 600) {
saveInterval = saveInterval + 300; //set value to 10 minutes (600 seconds)
} else if(saveInterval >= 600) {
saveInterval = 5;
lcd.setCursor(0,1);
lcd.print(" ");
if (saveInterval <= 60) {
lcd.setCursor(0,1);
lcd.setCursor(3,1);
} else if(saveInterval > 60) {
minutes = saveInterval / 60;
lcd.setCursor(0,1);
lcd.print(minutes);
lcd.setCursor(3,1);
lcd.print("minutes");
buttonState = buttonValue1;
lcd.setCursor(0,3);
lcd.print("Storing");
delay(400);
for (int i = 0; i <= 2; i++) {
lcd.print(".");
delay(350);
return saveInterval;
int lcdInt() {
int buttonValue1;
int buttonValue2;
int buttonState;
int minutes;
lcd.clear();
lcd.print("Choose LCD backlight");
lcd.setCursor(0,1);
lcd.print("timeout:");
lcd.setCursor(0,2);
lcd.print(lcdInterval);
lcd.setCursor(3,2);
delay(10);
if(lcdInterval >= 10 && lcdInterval < 30) {
lcdInterval = lcdInterval + 10;
} else if(lcdInterval >= 30 && lcdInterval < 60) {
lcdInterval = lcdInterval + 30;
} else if(lcdInterval >= 60 && lcdInterval < 120) {
lcdInterval = lcdInterval + 60;
} else if(lcdInterval >= 120 && lcdInterval < 300) {
lcdInterval = lcdInterval + 180;
} else if(lcdInterval >= 300 && lcdInterval < 600) {
lcdInterval = lcdInterval + 300;
} else if(lcdInterval >= 600) {
lcdInterval = 10;
lcd.setCursor(0,2);
lcd.print(" ");
if (lcdInterval <= 60) {
lcd.setCursor(0,2);
lcd.setCursor(3,2);
} else if(lcdInterval > 60) {
minutes = lcdInterval / 60;
lcd.setCursor(0,2);
lcd.print(minutes);
lcd.setCursor(3,2);
lcd.setCursor(0,3);
lcd.print("Starting");
delay(400);
lcd.print(".");
delay(350);
return lcdInterval;
void lcdPrintDouble( double val, byte precision){
if(val < 0.0){
lcd.print('-');
val = -val;
if (int(val) < 100) {
lcd.print(" ");
lcd.print(int(val));
lcd.print (int(val));
if( precision > 0) {
lcd.print(".");
unsigned long frac;
unsigned long mult = 1;
byte padding = precision -1;
while(precision--)
mult *=10;
if(val >= 0)
frac = (val - int(val)) * mult;
frac = (int(val)- val ) * mult;
unsigned long frac1 = frac;
while( frac1 /= 10 )
padding--;
while( padding--)
lcd.print("0");
lcd.print(frac,DEC) ;
and this error mesagges
sketch_jul04a.cpp: In function 'void setup()':
sketch_jul04a:119: error: 'saveInt' was not declared in this scope
sketch_jul04a.cpp: In function 'void loop()':
sketch_jul04a:183: error: a function-definition is not allowed here before '{' token
sketch_jul04a:357: error: expected `}' at end of input
