Help nedded with bmp280 and sh1106
HI can anyon help me with the error
Sensor Used: Bmp280
Board Arduino Nano
Oled
#include <Wire.h>
#include "i2c_BMP280.h"
#include "i2c.h"
#include "U8glib.h"
U8GLIB_SH1106_128X64 u8g(10, 9, 12, 11, 13); // SW SPI Com: SCK = 10, MOSI = 9, CS = 12, D/C = 11, RESET = 13
BMP280 bmp;
float pressure = 0.0;
float tempC = 0.0;
float altitude = 0.0;
void BmpSensorRead(float* pressure, float* tempC, float* altitude);
void DisplayPresTemp(float* pressure, float* tempC, float* altitude);
void setup(void)
  // assign default color value
  if (u8g.getMode() == U8G_MODE_R3G3B2)
    u8g.setColorIndex(255);     // white
  else if (u8g.getMode() == U8G_MODE_GRAY2BIT)
    u8g.setColorIndex(3);         // max intensity
  else if (u8g.getMode() == U8G_MODE_BW)
    u8g.setColorIndex(1);         // pixel on
  else if (u8g.getMode() == U8G_MODE_HICOLOR)
    u8g.setHiColorByRGB(255, 255, 255);
  for (int a = 0; a < 30; a++)
    u8g.firstPage();
    do
      u8g.setFont(u8g_font_fub11);
      u8g.setFontRefHeightExtendedText();
      u8g.setDefaultForegroundColor();
      u8g.setFontPosTop();
      u8g.drawStr(4, a, "BMP180 Sensor");
    while (u8g.nextPage());
  delay(3000);
if (bmp.initialize())
    u8g.firstPage();
    do
      u8g.drawStr(4, 0, "BMP085 Sensor");
      u8g.drawStr(4, 20, " ERROR!");
    Serial.println("BMP085 sensor, ERROR!");
    while (1) {}
void loop(void)
  BmpSensorRead(&pressure, &tempC, &altitude);
  DisplayPresTemp(&pressure, &tempC, &altitude);
  u8g.firstPage();
  do
    u8g.drawStr(2, 0, "Pressure");
    u8g.setPrintPos(75, 0);
    u8g.print(*pressure);
    u8g.drawStr(4, 20, "Temp C");
    u8g.setPrintPos(75, 20);
    u8g.print(*tempC);
    u8g.drawStr(4, 40, "Altitude");
    u8g.setPrintPos(75, 40);
    u8g.print(*altitude);
  *tempC = bmp.getTemperature();
  Serial.print("Temperature = ");
  Serial.print(*tempC);
  Serial.println(" *C");
  *pressure = bmp.readPressure() / 100.0;
  Serial.print("Pressure = ");
  Serial.print(*pressure / 100.0);
  Serial.println(" hPa");
  // Calculate altitude assuming 'standard' barometric
  // pressure of 1013.25 millibar = 101325 Pascal
  *altitude = bmp.readAltitude();
  Serial.print("Altitude = ");
  Serial.print(*altitude);
  Serial.println(" meters");
i get the following error
[color=red]no matching function for call to 'BMP280::getTemperature()'
[/color]
If I am looking at the right library (you should always link to any library that is not included in the IDE) there are 2 functions to read the temperature. Both require parameters. You are calling the function with no parameters and there is no overload (version) of that function that takes no parameters.
void getTemperature(int32_t& millicelsius)
void getTemperature(float& celsius)
HI i am using this Library
i still cant get it to work. the thing is i am trying to use it with g8lib to get temp displayed on oled
That conveys no information that is useful to help fix your problem. Have you written a small sketch to get the BMP to work by itself. If not, I suggest that you do.
Thanks for reply
here is the sketch for bmp280
#include <Wire.h>
#include "i2c.h"
BMP280 bmp280;
    Serial.print("Probe BMP280: ");
    if (bmp280.initialize()) Serial.println("Sensor found");
        Serial.println("Sensor missing");
        while (1) {}
    // onetime-measure:
    bmp280.setEnabled(0);
    bmp280.triggerMeasurement();
    bmp280.awaitMeasurement();
    float temperature;
    bmp280.getTemperature(temperature);
    Serial.print(temperature);
    Serial.println(" C");
And it provides the results that you expect or not?
yes it does
Probe BMP280: Sensor found
23.63 C
23.68 C
now i want to disply it on my oled using u8glib
any help please
Have you written a small sketch, without any other code, that can display a canned message on the OLED display or have you gotten any of the examples that come with the U8glib library to work?
HeyMate thanks bud managed to get it to work
#include <Wire.h>
#include "i2c.h"
#include "U8glib.h"
BMP280 bmp280;
float tempC;
void BmpSensorRead(float* tempC);
void DisplayTemp(float* tempC);
void setup(void)
        while (1) {}
    // onetime-measure:
void loop(void)
  BmpSensorRead(&tempC);
  DisplayTemp(&tempC);
  delay(10000);
  u8g.firstPage();
  do
    u8g.setFont(u8g_font_courB24);
    u8g.drawStr(4, 20, "T");
    u8g.print(*tempC);
   float temperature;
*tempC = temperature;
