Help need for compiling code
Hallo,
ich bekomme einen sehr komischen Fehler den ich nicht verstehe.
Hier ist mein Code
// Example project which can be built with SSL enabled or disabled.
// The espressif8266_stage platform must be installed.
// Refer to platformio.ini for the build configuration and platform installation.
#if defined(ESP8266)
#include <Arduino.h>
#include <ESP8266WiFi.h>
#include <Ticker.h>
#include <AsyncMqttClient.h>
#else
#include <WiFi.h>
#include <AsyncTCP.h>
#include <ESPmDNS.h>
#include <Ticker.h>
#endif
#define WIFI_SSID "My_Wi-Fi"
#define WIFI_PASSWORD "my-awesome-password"
#define MQTT_HOST IPAddress(192, 168, 1, 10)
#if ASYNC_TCP_SSL_ENABLED
#define MQTT_SECURE true
#define MQTT_SERVER_FINGERPRINT {0x7e, 0x36, 0x22, 0x01, 0xf9, 0x7e, 0x99, 0x2f, 0xc5, 0xdb, 0x3d, 0xbe, 0xac, 0x48, 0x67, 0x5b, 0x5d, 0x47, 0x94, 0xd2}
#define MQTT_PORT 8883
#else
#define MQTT_PORT 1883
#endif
AsyncMqttClient mqttClient;
Ticker mqttReconnectTimer;
WiFiEventHandler wifiConnectHandler;
WiFiEventHandler wifiDisconnectHandler;
Ticker wifiReconnectTimer;
void connectToWifi() {
  Serial.println("Connecting to Wi-Fi...");
  WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
void connectToMqtt() {
  Serial.println("Connecting to MQTT...");
  mqttClient.connect();
void onWifiConnect(const WiFiEventStationModeGotIP& event) {
  Serial.println("Connected to Wi-Fi.");
  connectToMqtt();
void onWifiDisconnect(const WiFiEventStationModeDisconnected& event) {
  Serial.println("Disconnected from Wi-Fi.");
  mqttReconnectTimer.detach(); // ensure we don't reconnect to MQTT while reconnecting to Wi-Fi
  wifiReconnectTimer.once(2, connectToWifi);
void onMqttConnect(bool sessionPresent) {
  Serial.println("Connected to MQTT.");
  Serial.print("Session present: ");
  Serial.println(sessionPresent);
  uint16_t packetIdSub = mqttClient.subscribe("test/lol", 2);
  Serial.print("Subscribing at QoS 2, packetId: ");
  Serial.println(packetIdSub);
  mqttClient.publish("test/lol", 0, true, "test 1");
  Serial.println("Publishing at QoS 0");
  uint16_t packetIdPub1 = mqttClient.publish("test/lol", 1, true, "test 2");
  Serial.print("Publishing at QoS 1, packetId: ");
  Serial.println(packetIdPub1);
  uint16_t packetIdPub2 = mqttClient.publish("test/lol", 2, true, "test 3");
  Serial.print("Publishing at QoS 2, packetId: ");
  Serial.println(packetIdPub2);
void onMqttDisconnect(AsyncMqttClientDisconnectReason reason) {
  Serial.println("Disconnected from MQTT.");
  if (reason == AsyncMqttClientDisconnectReason::TLS_BAD_FINGERPRINT) {
    Serial.println("Bad server fingerprint.");
  if (WiFi.isConnected()) {
    mqttReconnectTimer.once(2, connectToMqtt);
void onMqttSubscribe(uint16_t packetId, uint8_t qos) {
  Serial.println("Subscribe acknowledged.");
  Serial.print("  packetId: ");
  Serial.println(packetId);
  Serial.print("  qos: ");
  Serial.println(qos);
void onMqttUnsubscribe(uint16_t packetId) {
  Serial.println("Unsubscribe acknowledged.");
void onMqttMessage(char* topic, char* payload, AsyncMqttClientMessageProperties properties, size_t len, size_t index, size_t total) {
  Serial.println("Publish received.");
  Serial.print("  topic: ");
  Serial.println(topic);
  Serial.println(properties.qos);
  Serial.print("  dup: ");
  Serial.println(properties.dup);
  Serial.print("  retain: ");
  Serial.println(properties.retain);
  Serial.print("  len: ");
  Serial.println(len);
  Serial.print("  index: ");
  Serial.println(index);
  Serial.print("  total: ");
  Serial.println(total);
void onMqttPublish(uint16_t packetId) {
  Serial.println("Publish acknowledged.");
  wifiConnectHandler = WiFi.onStationModeGotIP(onWifiConnect);
  wifiDisconnectHandler = WiFi.onStationModeDisconnected(onWifiDisconnect);
  mqttClient.onConnect(onMqttConnect);
  mqttClient.onDisconnect(onMqttDisconnect);
  mqttClient.onSubscribe(onMqttSubscribe);
  mqttClient.onUnsubscribe(onMqttUnsubscribe);
  mqttClient.onMessage(onMqttMessage);
  mqttClient.onPublish(onMqttPublish);
  mqttClient.setServer(MQTT_HOST, MQTT_PORT);
  mqttClient.setSecure(MQTT_SECURE);
  if (MQTT_SECURE) {
    mqttClient.addServerFingerprint((const uint8_t[])MQTT_SERVER_FINGERPRINT);
#endif
  connectToWifi();
Hier ist der Fehler
 error: 'WiFiEventHandler' does not name a type; did you mean 'WiFiEventFuncCb'?
 WiFiEventFuncCb
WiFiEventHandler gehört zum ESP8266 und nicht zum ESP32. Dein Code passt also nicht zum Prozessor-Core.
Gruß Tommy
Die Ursache hat @Tommy56 bereits aufgezeigt.
Die als WiFiEventHandler deklarierten Funktionen legen das Verhalten beim Connect mit bzw. Disconnect vom WLAN fest. Das sollte sich beim ESP32 durch die Funktion Wifi.onEvent() umsetzen lassen. Siehe dieses Beispiel
#include <WiFi.h>
const char* ssid = "yourNetworkName";
const char* password = "yourNetworkPassword";
void connected_to_ap(WiFiEvent_t wifi_event, WiFiEventInfo_t wifi_info){
    Serial.println("[+] Connected to the WiFi network");
void disconnected_from_ap(WiFiEvent_t wifi_event, WiFiEventInfo_t wifi_info){
    Serial.println("[-] Disconnected from the WiFi AP");
    WiFi.begin(ssid, password);
void got_ip_from_ap(WiFiEvent_t wifi_event, WiFiEventInfo_t wifi_info){
    Serial.print("[+] Local ESP32 IP: ");
void setup(){
    WiFi.mode(WIFI_STA); //Optional
    WiFi.onEvent(connected_to_ap, SYSTEM_EVENT_STA_CONNECTED);
    WiFi.onEvent(got_ip_from_ap, SYSTEM_EVENT_STA_GOT_IP);
    WiFi.onEvent(disconnected_from_ap, SYSTEM_EVENT_STA_DISCONNECTED);
    Serial.println("\nConnecting");
void loop(){}
von der Seite https://www.upesy.com/blogs/tutorials/how-to-connect-wifi-acces-point-with-esp32
Zusätzliche Informationen (z.B. eine Tabelle der ESP32 Wifi Events) siehe hier
https://randomnerdtutorials.com/esp32-useful-wi-fi-functions-arduino/
