help need help programming arduino to do certain commands for project
I need the Arduino to turn on with the push button then allow me to change the brightness of it. For example, with the push button i turn on the led and it stays on. Then after I turn it on I would want it to allow me to change the brightness of it by using a potentiometer. I did the following code but it said in the Arduino " ^ exit status 1 expected unqualified-id before '{' token " I would please prefer to have an answer by June 2, 2018 or before please. and thank you for reading. I really THANK YOU.
CODE:
define led 9
define knob 0
int pushbuttonPin = 4; int val = 0; int lightON = 0; int pushed = 0;
void setup(){ Serial.begin (9600); pinMode(pushbuttonPin,INPUT); delay(100); }
{ pinMode(led, OUTPUT); } void loop(){ val = digitalRead(pushbuttonPin); if(val == HIGH && lightON == LOW){ pushed = 1-pushed; delay(100); } lightON = val; if(pushed == HIGH){ Serialprint.ln("Light ON"); }else{ Serial.println("Light OFF"); } delay(100); { int val = analogRead(knob); val = map(val, 1, 1024, 1, 255); analogWrite(led, val); }
delay(100);
The commented brackets are strays and cause some error(s).
Dot in the wrong place.
delay(100);
Another stray bracket
Please read the "how to use the forum-please read" stickies.
add } to the last line
It is also fortunate that the current definition of HIGH is 1 and the current definition of LOW is 0.
