Help! Need to complete code
Hi, I'm trying to complete a code using a couple of leds, one servo, two buttons (one to start, other to interrupt the process), a buzzer and a tilt sensor.
When the start button is pushed, ledPin1 must turn on, ledPin2 off, servo start and delay for a minute (can't make sweep slower either). After completed, ledPin1 must turn off, ledPin2 on and the buzzer on for an alarm that stops when the tilt sensor is activated.
I have the main codes but can't connect them to make them work in such sequence. Please help!
//constants won't change. Used to set pin numbers:
const int buttonPin1 = 2;   // Start/stop button
const int buttonPin2 = 4;   // Pause/play button
const int ledPin1 = 13;     // Red led: timer starts
const int ledPin2 = 5;      // Green led: timer stops, break time
const int buzzer = 8;       // buzzer alert
const int switchTilt = 7;   // tilt sensor
const int servoPin = 9;     // servo
//variables will change:
int buttonState = 0;        // Variable for reading the start button status
int val = 0;                // value tilt sensor
#include <Servo.h>
Servo servo_9;
int angle = 0;              // servo position in degrees
pinMode(13, OUTPUT);          // ledPin1: red led
pinMode(5, OUTPUT);           // ledPin2: green led
pinMode(2, INPUT_PULLUP);     // buttonPin1: start stop button
pinMode(4, INPUT_PULLUP);     // buttonPin2: pause play button
pinMode(7, INPUT);            // switchTilt
pinMode(8, OUTPUT);           // buzzer
servo_9.write(angle); //sets initial position
servo_9.attach(9);            // servo
digitalRead(3);
digitalRead(5);
digitalRead(7);
digitalRead(8);
digitalRead(9);
digitalRead(13);
/*if buttonPin1 pushed, ledPin1 on, ledPin2 off, timer and servo on.
when finished or servo in 0 position, ledPin1 off, ledPin2 on, buzzer on.
buzzer off and ledPin2 off when tilt sensor moved.
buttonState = digitalRead(2);    // read the state of pushbutton start
if (buttonState == HIGH) {      // if button start pushed
  digitalWrite(13, HIGH);      // red led on
  digitalWrite(5, LOW);        // green led off
for(angle = 0; angle < 180; angle+=1)    // sweep from 0 to 180 degrees (figure out timer)
  servo_9.write(180);
delay (2000);
else {
  digitalWrite(13, LOW);       // red led off
  digitalWrite(5, HIGH);       // green led on
  tone(8, 1000);          // 1khz sound signal for 1 sec, then stop for 1 sec
  delay (1000);
  noTone(8);
  delay (2000);
for(angle = 180; angle > 0; angle-=1)   // sweep from 180 to 0 degrees
  servo_9.write(0);
  delay (1000);
val = digitalRead(7);    // switchTilt
if (val == HIGH){
  digitalWrite(5, LOW);  //green led off
  noTone(8);             // buzzer off
buttonState = digitalRead(4);
if (buttonState == HIGH){
  delay (1000);
delay(10); // Delay a little bit to improve simulation performance
You define your pin numbers as constants at the beginning of the program (good) and then you use the actual pin numbers throughout your program (bad).
I would suggest you look of this thread to see how to do multiple things at the same time.
You could also do this by using a state machine (look up finite state machine) but that might be more advanced than you want/need.
