Help need to set up hardware
Hello,
I need an hardware set up able to perform a specific task. If possible I'll ask you to give me some help selecting the components and how to set them up.
This hardware must be able to store in its memory an arbitrary waveform and output it in an analog way through 8 channels independently and on demand. For example:
With the signal previously stored in memory, activate the output on channel 1. Before this output ends and without affecting it (so it will continue outputting the signal until it ends), start outputting the stored signal on a separate channel.
This simultaneous outputting must be independent and may be not synchronized.
An external source of triggering, or another programmable component be used.
More specifically:
Store in memory a certain arbitrary waveform sampled with 8 bit resolution and able to store up to 50000 points.
Ouput the stored waveform to an analog signal with voltages up to 30Vpp. The output should be triggered externally or using another programmable component.
I have an hardware capable of being used as a trigger. It can ouput analog signal at a 100MHz frequency with voltages up to 12Vpp.
If this setup is feasible I would ask you to give me the necessary components list so I can order them and the project to assemble the hardware.
Thank you very much in advance.
Best regards,
Carlos Silva
