Help!!! need transmit/receive code
Currently i am building a remote control using 2 arduino Arduino 1 for transmitter Arduino 2 for receiver
i want to send joystick position data using the transmitter and the receiver should get the data and output as PWN
i am wondering how to write the code to send and get the data i am confusing with the data type
That's wht i think(not a completed code)
for transmitter
byte joyValue=0;
joyValue= map(analogRead(0),0,1023,0,127);
Serial.print(joyValue, BYTE);
for receiver
int inByte;
inByte = Serial.read();
digitalWrite(6,inByte);
is it going to work? if i sent one byte at a time, can the receiver save that byte as integer value?
thank you :D
If you want to output as PWM you need to do analogWrite.
Also, don't forget that the receiver needs to wait until a character is available in the serial port before reading, see: http://www.arduino.cc/en/Serial/Available
Not sure whay you only map to 127, you could map the full 0-255 values that analogWrite can handle.
Have fun!
thanks but i want to know is that ok using the Serial.print(joyValue, BYTE) to send the signal through Xbee pairs
and the receiver will store this value using int inByte=Serial.Read();
so if joyValue =255 , i will get inByte=255.
is that right?
