Help Needed!! Controling Servo Angle Trhough Xbee
hi everyone…
i just start using Arduino, and now i am trying to control servo angle with pushbutton wirelessly…
i use two Arduino UNO and two Xbee Module with Xbee Shield…
But it does’t work when i try to run it =( =(.Can anyone figure out what is wrong?
servo only moves 120 degrees and a few seconds later moving to 180 degrees even though the button has been pressed
here’s the transmitter code
const int buttonPin = 11; int buttonState; void setup() { pinMode(buttonPin, INPUT); digitalWrite( buttonPin, HIGH); Serial.begin(9600); } void loop() { buttonState = digitalRead(buttonPin); if (buttonState == LOW) { Serial.print("1"); } else { Serial.print("0"); } Serial.println(buttonState); delay(100); }
and the receiver
``#include <Servo.h>
#define right 120
#define left 10
int data;
int servoPin = 9;
Servo angelaServo;
angelaServo.attach(servoPin);
if (Serial.available() > 0)
data = Serial.read();
if (data == 0)
angelaServo.write(right);
angelaServo.write(left);
Any help appreciated. Thanks. :slight_smile:
Do not cross post. You posted this already.
After
have you tried printing data to see what you are actually getting ?
How about some Serial.prints so that you know which portions of code are being executed ?
What have you got the line ending set to in the Serial monitor ?
The transmitter sends “1” or “0” but in the receiver you check for an int value of 1 or 0. Are they ever going to be equal I wonder …
use two Arduino UNO
We know exactly which Arduino.
and two Xbee Module
but not which XBee...
with Xbee Shield...
or shield.
Nor do we have a clue as to how you configured them. If you followed Digi's advice that they work out of the box, then you should be on Digi's site asking them why the f**k they aren't working.
It Works now guys…
thanks for help :slight_smile:
here’s the code i use
transmitter
const int buttonPin = 8; const int ledPin = 13; int buttonState = 0; void setup() { Serial.begin(9600); pinMode(buttonPin, INPUT_PULLUP); } void loop() { buttonState = digitalRead(buttonPin); if (buttonState == HIGH) { Serial.write(1); } else { Serial.write(0); } delay(50); }
and the receiver
#define up 100
#define down 170
char data;
int servoPin = 9;
Servo angelaServo;
pinMode(servoPin, OUTPUT);
angelaServo.write(down);
void process_incoming_command(char cmd)
int speed = 100;
switch (cmd)
case ‘1’:
case 1:
angelaServo.write(up);
case ‘0’:
case 0:
if (Serial.available() >= 1)
char cmd = Serial.read();
process_incoming_command(cmd);
it works perfectly, i have another question guys, what if i use additional sensors? potentiometer for example, how to do that?? thank you
case '1':
  case 1:
You still don't quite get it, do you ?
What do you expect from a person who can't even paste the code INSIDE the tags?
sorry all I am still a newbie, that's why I am here asking for your help, thank you for your help
[code]
your sketch
[/code]
