Help Needed - Controlling 3 stepper motors through a Gecko G540
Hi All
I am starting to loop a little bit in my first attempt at setting up an old CNC mill that I want to control off of 2 joysticks. I am trying to get the X, Y & Z on the joysticks and the centre press on both joysticks to toggle through 3 speeds for the steppers.
Attached is what I have come up with for wiring but the code side of things I am struggling to find exactly what I need.
So I have 2 questions -
1 - does this wiring diagram look correct for what I am trying to do?
2 - would there be anyone able to assist in helping me write the code?
Hopefully I have made some sense and not confused everyone!
Thanks
Dwayne
here
in your circuit, there should be a common ground between driver and arduino
hi KASSIMSAMJI , ive had a look at that one didnt seem to cover what i was looking for… but could be just me… lol i dont know what im doing…
ive found a code that ive hacked at… but 100% got no idea… this look ok?
also changed the wireing lay out added limit switches in attachment…
#define step_pin 2  // Pin 2 connected to X Steps pin 2 on g540
#define dir_pin 3   // Pin 3 connected to X Direction pin 3 on g540
#define step_pin 4  // Pin 4 connected to Y Steps pin 4 on g540
#define dir_pin 5   // Pin 5 connected to Y Direction pin 5 on g540
#define step_pin 6  // Pin 6 connected to Z Steps pin 6 on g540
#define dir_pin 7   // Pin 7 connected to Z Direction pin 7 on g540
#define X_pin A0    // Pin A0 connected to joystick VRx axis
#define Y_pin A1    // Pin A1 connected to joystick VRy axis
#define X_pin A2    // Pin A2 connected to joystick VRz axis
#define Joy_switch 8  // Pin 8 connected to joystick switch
#define Limit + 10  // Pin 10 connected to Limit switch +
#define Limit - 9   // Pin 9  connected to Limit switch -
int step_speed = 10;  // Speed of Stepper motor (higher = slower)
  pinMode(dir_pin, OUTPUT);
  pinMode(step_pin, OUTPUT);
  pinMode(SLEEP, OUTPUT);
  pinMode(Limit+, INPUT);
  pinMode(Limit-, INPUT);
  pinMode(Joy_switch, INPUT_PULLUP);
  digitalWrite(SLEEP, HIGH);  // Wake up g540
  delay(5);  // Wait for g540 wake up
/* Configure type of Steps on g540
// LOW LOW = Full Step //
// HIGH LOW = Half Step //
// LOW HIGH = A quarter of Step //
// HIGH HIGH = An eighth of Step //
 if (!digitalRead(Joy_switch)) {  //  If Joystick switch is clicked
   delay(500);  // delay for deboucing
   switch (step_speed) {  // check current value of step_speed and change it
     case 1:
       step_speed=10;  // slow speed
     case 3:
       step_speed=1;  // fast speed
     case 10:
       step_speed=3;  // medium speed
 if (analogRead(X_pin) > 712) {  //  If joystick is moved Left
   if (!digitalRead(Limit+)) {}  // check if limit switch is activated
     else {  //  if limit switch is not activated, move motor clockwise
       digitalWrite(dir_pin, LOW);  // (HIGH = anti-clockwise / LOW = clockwise)
       digitalWrite(step_pin, HIGH);
       delay(step_speed);
       digitalWrite(step_pin, LOW);
       delay(step_speed);
   if (analogRead(X_pin) < 312) {  // If joystick is moved right
   if (!digitalRead(Limit-)) {}  // check if limit switch is activated
     else {  //  if limit switch is not activated, move motor counter clockwise
       digitalWrite(dir_pin, HIGH);  // (HIGH = anti-clockwise / LOW = clockwise)
       delay(step_speed);
       delay(step_speed);
see sticky post above and learn how to use code tags please
so did you test that code? if yes ,what worked and what didn't?
KASSIMSAMJI:
so did you test that code? if yes ,what worked and what didn’t?
hi, got the code tags sorted…
and no, i did more research on the code and it was for use with a “Easy Driver board” so i don’t think it will work with the g540 so back to square one
It would help if you write what you expect to happen, what components you have (are these 2 gray things joysticks or what?), do the components work as intended, ....
