Help Needed: Debugging Arduino Portenta C33 Code for Logging Data to Google Sheets via Web App URL
Hello Arduino Community,
I’m currently working on a project using an Arduino Portenta C33 and I’m trying to log data from my device to Google Sheets via a web app URL. I’m using the WiFiC3 library to establish a WiFi connection, and I have written a script that sends data to a Google Sheets web app endpoint. However, I’m facing some issues with getting it to work.
What I’ve Done So Far:
  1. I’ve created a Google Apps Script Web App that receives HTTP requests and logs data to a Google Sheet. I’ve confirmed the Web App URL works fine when tested in a browser AND postman
  2. No library called WiFiClientSecure.h
  3. No available method .setInsecure under the calss WiFiClient, which is included in WiFiC3.h
  4. Using httpsPort = 80 without changing the rest of the code results in error printed to Serial Monitor
Problem:
  • No data is appearing in the Google Sheets document when I try to send data from the Portenta C33.
  • I’ve checked my network connection, and the WiFi appears to be working, but the communication with the web app seems to be failing
  • secureClient.available() returns false
Code Snippet:
#include <WiFiC3.h>
const char* ssid = "";
const char* password = "";
const char* host = "script.google.com";
const int httpsPort = 443;
// Use WiFiClientSecure class to create TLS connection
WiFiClient secureClient;
// Replace with your GAS service ID (Google Apps Script Web App URL)
String APP_ID= "";
  delay(10);
  // Connect to WiFi
  WiFi.begin(ssid, password);
  float pressure = 101.35;
  // Send data to Google Sheets
  if (secureClient.connect(host, httpsPort)) {
    String url = "/a/macros/s/" + APP_ID + "/exec?Pressure=" + String(pressure);
    Serial.print("Requesting URL: ");
    Serial.println(url);
    secureClient.print(String("GET ") + url + " HTTP/1.1\r\n" +
                   "Host: " + host + "\r\n" +
                   "User-Agent: Arduino\r\n" +
                   "Connection: close\r\n\r\n");
  delay(5000); // Read every 0.5 second
Are there specific libraries or configurations I may need for better handling HTTP requests from the Portenta C33? I’d greatly appreciate any help or insights you might have to resolve this issue!
Thank you in advance!
