Hi everyone,
I'm working on a project to send keystrokes via Bluetooth LE from an ESP32 to an Android TV, but I've run into two problems that I can’t seem to solve.
The basic setup works as follows: for testing, I send a keystroke using a simple HTTP request (e.g., curl -X GET "http://<ESP-IP>/send?keycode=102"). This successfully sends a power on/off command to the Android TV box.
** My Issues:**
- Reconnection after ESP32 Power Cycle:
If I power cycle the ESP32, it reconnects to the Android TV box, but keystrokes are no longer processed by the TV. The ESP32 logs indicate that the keystrokes are being sent, but nothing happens on the TV. To fix this, I have to unpair and re-pair both devices. After re-pairing, everything works fine—until the ESP32 is power cycled again. - Deep Standby Mode on Android TV:
When the Android TV enters deep standby, the Bluetooth connection to the ESP32 breaks, and I cannot send the power-on command. However, regular remote controls can still wake the box, even when it’s in deep standby.
I’m unsure how to tackle these challenges and would greatly appreciate any advice or guidance. My code is attached for reference. I’m using PlatformIO with the Arduino framework.
Thank you in advance for your help!
#include <Arduino.h>
#include <BLEDevice.h>
#include <BLEUtils.h>
#include <BLEServer.h>
#include <BLEHIDDevice.h>
#include <HIDTypes.h>
#include <HIDKeyboardTypes.h>
#include <ESPAsyncWebServer.h>
#include <WiFi.h>
BLEHIDDevice* hid;
BLECharacteristic* input;
BLEServer* pServer;
const char* ssid = "MyAp";
const char* password = "1234";
AsyncWebServer server(80);
class MyServerCallbacks : public BLEServerCallbacks {
void onConnect(BLEServer* pServer) {
Serial.println("Gerät verbunden");
void onDisconnect(BLEServer* pServer) {
Serial.println("Verbindung getrennt, starte Werbung neu...");
pServer->startAdvertising();
Serial.println("Starte BLE HID Tastatur...");
// WiFi-Verbindung herstellen
WiFi.begin(ssid, password);
Serial.println("Verbinde mit WiFi...");
Serial.println("WiFi verbunden");
// BLE initialisieren
BLEDevice::init("ESP32 Keyboard");
pServer = BLEDevice::createServer();
pServer->setCallbacks(new MyServerCallbacks());
hid = new BLEHIDDevice(pServer);
input = hid->inputReport(1); // Report ID 1
hid->manufacturer()->setValue("ESP32");
uint8_t reportMap[] = {
0x05, 0x01, // Usage Page (Generic Desktop)
0x09, 0x06, // Usage (Keyboard)
0xA1, 0x01, // Collection (Application)
0x85, 0x01, // Report ID (1) - Keyboard Report
0x05, 0x07, // Usage Page (Key Codes)
0x19, 0xE0, // Usage Minimum (Left Control)
0x29, 0xE7, // Usage Maximum (Right Control)
0x15, 0x00, // Logical Minimum (0)
0x25, 0x01, // Logical Maximum (1)
0x75, 0x01, // Report Size (1)
0x95, 0x08, // Report Count (8)
0x81, 0x02, // Input (Data, Variable, Absolute) - Modifier byte
0x95, 0x01, // Report Count (1)
0x75, 0x08, // Report Size (8)
0x81, 0x01, // Input (Constant) - Reserved byte
0x95, 0x05, // Report Count (5)
0x05, 0x08, // Usage Page (LEDs)
0x19, 0x01, // Usage Minimum (Num Lock)
0x29, 0x05, // Usage Maximum (Kana)
0x91, 0x02, // Output (Data, Variable, Absolute) - LED report
0x75, 0x03, // Report Size (3)
0x91, 0x01, // Output (Constant) - LED report padding
0x95, 0x06, // Report Count (6)
0x25, 0xFF, // Logical Maximum (101)
0x19, 0x00, // Usage Minimum (0)
0x29, 0xFF, // Usage Maximum (255)
0x81, 0x00, // Input (Data, Array) - Key array (6 keys)
0xC0 // End Collection
hid->reportMap(reportMap, sizeof(reportMap));
hid->startServices();
BLEAdvertising* pAdvertising = pServer->getAdvertising();
pAdvertising->setAppearance(HID_KEYBOARD);
pAdvertising->addServiceUUID(hid->hidService()->getUUID());
pAdvertising->start();
Serial.println("BLE HID Tastatur gestartet, warte auf Verbindung...");
// HTTP-Server konfigurieren
server.on("/send", HTTP_GET, [](AsyncWebServerRequest *request){
if (request->hasParam("keycode")) {
String keycodeStr = request->getParam("keycode")->value();
uint8_t keyCode[8] = {0};
keyCode[2] = keycodeStr.toInt(); // Konvertiere String zu int
input->setValue(keyCode, sizeof(keyCode));
input->notify();
Serial.println("Keycode gesendet: " + keycodeStr);
// Taste loslassen
delay(100); // Kurze Verzögerung
memset(keyCode, 0, sizeof(keyCode));
input->notify();
Serial.println("Taste losgelassen");
request->send(200, "text/plain", "Keycode gesendet: " + keycodeStr);
request->send(400, "text/plain", "Fehlender Parameter: keycode");
server.begin();
// Keine Datenübertragung in der loop-Funktion
