Help needed for PAN TILT project
plz send code DC motor PAN TILT project
Arduino + Motor drive shield
Arduino + Adafruit Motor/Stepper/Servo Shield
Arduino + L298N Stepper / Dc Motor Driver Controller
Shahbaz:
plz send code
Firstly Shahbaz you should start a fresh thread for this- it's not an answer to this thread's OP's question. I've asked mods to split it out if they can. Thanks Rob.
Second, this is is not a code shop where you put in an order for code. It's a forum of Arduino enthusiasts who help each other. That means you go first and post code that you're having trouble with and someone will very likely help you, or at least try. If you do want someone to "send code" then post here but be prepared to pay.
Third, or maybe this one should be first, read this.
moderator:
  • split of the project
  • added more meaningful title
