Help needed for strtok function
Hello,
I need some help with the strtok function. I have a string with a label and 16 integers like theis :
Qs323=976;456;890;1000;24;876;0;432;0;1000;1000;989;745;0;876;5
I would like to split the string by extracting all the integers separated by semicoluns. The result will be :
integer1=976 integer2=456 .... integer16=5
I wrote a code like this :
equalPosition = rawIncomingString.indexOf('=');
                  variableLabel = rawIncomingString.substring(0, equalPosition);
                  trimIncomingString = rawIncomingString.substring(equalPosition+1, rawIncomingString.length());
                  rawIncomingString = "";
                  semicolunPosition = trimIncomingString.indexOf(';');
                  integer1String = trimIncomingString.substring(0, semicolunPosition);
                  trimIncomingString = trimIncomingString.substring(semicolunPosition+1, trimIncomingString.length());
                  integer1 = integer1String.toInt();
The string incoming is named "rawIncomingString". The 2 first lines separate the label "Qh323" from the string and store it into variableLabel string. The 2 next lines build a new string named trimIncoming string witch looks like :
The 4 next lines separate the first integer, convert to int and store into integer1 int.
My problem is that I need to repeat the operation 16 times. I think the strtok function will be more efficient but I don't know how to use it. Could somebody help me and send a piece of code with my example ? Thanks a lot
const int MAX_LEN = 80;
const char lineEnding = '\n'; // whatever marks the end of your input.
char inputSentence [MAX_LEN + 1];
const byte MAX_TOKENS = 4;
const char* delimiters = ", "; // whatever characters delimit your input string
char* tokens [MAX_TOKENS + 1];
    int tokenIndex = 0;
    Serial.println (inputSentence);
    tokens [tokenIndex] = strtok (inputSentence, delimiters);
    while ((tokenIndex < MAX_TOKENS - 1) && tokens [tokenIndex])
      tokens [++tokenIndex] = strtok (NULL, delimiters);
Thank you. I don't see where is the output. My knowledge is very limited unfortunately. Could you adapt the code to my precise problem and explain a little bit more ? It would be very nice.
Here is the code I built for testing :
#include <Ethernet.h>
#include <SPI.h>
const char* delimiters = ";"; // whatever characters delimit your input string
byte mac[] = {  0x90, 0xA2, 0xDA, 0x0F, 0x19, 0x73 }; // MAC adress of the ethernet shield
byte IP [] = { 192,168,1,21 }; // IP Adress of the ethernet shield
byte server [] = { 192,168,1,20 }; // IP adress of PSX server
int serverPort=10748; // Port used by PSX server for data
String Qs323 = "Essai";
Client client (server, serverPort);
int equalPosition;
String rawIncomingString;
String trimIncomingString;
String variableLabel;
Ethernet.begin(mac, IP); // Connecting to server
  if (client.connected())
      if (client.available())
          char c = client.read();
          rawIncomingString += c;
          if (c == '\n')
              if (rawIncomingString.startsWith(Qs323))
                  int tokenIndex = 0;
                  Serial.println (trimIncomingString);
                  tokens [tokenIndex] = strtok (trimIncomingString, delimiters);
The debugger says :
sketch_jul30a.cpp: In function ‘void loop()’:
sketch_jul30a:50: error: cannot convert ‘String’ to ‘char*’ for argument ‘1’ to ‘char* strtok(char*, const char*)’
What is wrong ?
What is wrong ?
cannot convert 'String' to 'char*' for argument '1' to 'char* strtok(char*, const char*)'
Dump String, use simple C strings
I'm lost. Could you be more precise for me please ?
This is a String String Qs323 = "Essai";
This is a string char* Qs323 = "Essai"; or char Qs323 [6] = "Essai";
Don't use String - they are not appropriate for memory-limited machines like the Arduino.
Understood, but if I declare strings like this, I don’t have to functions .startswith, substring, etc…
The error is now :
Essai_strtok.cpp: In function ‘void loop()’:
Essai_strtok:44: error: request for member ‘startsWith’ in ‘rawIncomingString’, which is of non-class type ‘char*’
Essai_strtok:46: error: request for member ‘indexOf’ in ‘rawIncomingString’, which is of non-class type ‘char*’
Essai_strtok:47: error: request for member ‘substring’ in ‘rawIncomingString’, which is of non-class type ‘char*’
Essai_strtok:48: error: request for member ‘substring’ in ‘rawIncomingString’, which is of non-class type ‘char*’
#include <SPI.h>
int equalPosition;
char* rawIncomingString;
char* trimIncomingString;
char* variableLabel;
          if (c == '\n')
                  int tokenIndex = 0;
No, but you've got a different family of functions like "strstr", "strchr" etc.
Thank you very much !
I cannot adapt to my project as described. If somebody can take time to rewrite it it would be so nice. My knowledge is very limited but I need this.
This may help explain what AWOL was trying to tell you:
char message[] = "Qs323=976;456;890;1000;24;876;0;432;0;1000;1000;989;745;0;876;5";
const byte MAX_TOKENS = 20;
const char* delimiters = ",;="; // whatever characters delimit your input string
  // put your setup code here; to run once:
    int tokenIndex = 0;
    Serial.println (message);
    tokens [tokenIndex] = strtok (message, delimiters);
    for (int i = 0; i < tokenIndex; i++)
    Serial.println(tokens[i]);
Thank you very much for all. My message come from Ethernet server and I first need to put out the "Qh=" then split all values into separate integers. The message comes also many times with different values and I need to repeat every time. Examples you give me are always from static message.
You just need to apply the same method to your dynamic messages.
Believe me, I try from 3 hours already...
But we can't see your code, so we can't really help.
Ok ! After about 6 hours to do something many of you would have done within 15 minutes, I adapted the pieces of code you gave me to my usage (dynamic chars comming from network, Qs323 detection, split and store into integers). I want to thank you for your big help and patience. I adapted also fo debugging with serial communication replacing Ethernet. My last problem is about the char array named : rawIncomingCharArray which stores the incoming chars and test them to know if the message received begins with “Qs323”. The problem is that I want to clear this array after every loop, Qs323 detected or not, in order to have a new fresh empty array ready for new incoming chars and testing. I tried memset(rawIncomingCharArray, 0, 80); but the Arduino freezes after the first loop. A last help will be appreciated. Here is my code :
#include <SPI.h>
const byte MAX_TOKENS = 8;
const char* delimiters = "=;"; // Whatever characters delimit your input string
byte index = 0;
char rawIncomingCharArray[80];
int integer1;
int integer2;
//Client client (server, serverPort);
//Ethernet.begin(mac, IP); // Connecting to server
  //if (client.connected())
        if (Serial.available()) // CHANGE FOR CLIENT
            char c = Serial.read(); // CHANGE FOR CLIENT
            rawIncomingCharArray[index++] = c;
            if (c == ' ') // REPLACE WITH '\n'
                Serial.println(rawIncomingCharArray);
                if (strstr(rawIncomingCharArray, "Qs323"))
                    Serial.println("Qs323 detected");
                    int tokenIndex = 0;
                    Serial.println (rawIncomingCharArray);
                    tokens [tokenIndex] = strtok (rawIncomingCharArray, delimiters);
                      integer1 = atoi(tokens[1]);
                      integer2 = atoi(tokens[2]);
                    Serial.println(integer1);
                    Serial.println(integer2);
Every time you read a character and buffer it in the array, you must write a zero to the next location in the array.
When you’ve finished processing the string, simply reset the array index, and write a zero to the first location in the buffer.
Any example ? It's not very clear for me, sorry again.
rawIncomingCharArray[index] = '\0';
