Help needed for ultrasonic with ESP8266-01
Hi guys, there is so many tutorial on ultrasonic range finder using HC-SR04, can i use this project as wireless? I mean I have a ESP8266 wifi module, and I know it can use with PIR, but can I use HC-SR04 so that I can recive data in wireless? :slight_smile:
I am newbie in arduino, :confused:
so I'm not a coder guy! can you help me please? :confused:
Sure you can. I recommend you do the project in three stages:
  • Write a sketch that uses the ESP8266 to get distance readings from the HC-SR04 and print them to the Serial Monitor.
  • Write a sketch that sends the string "hello world" from your ESP8266 to some other device (computer or whatever you want to receive the HC-SR04 readings on) via WiFi.
  • Combine the two sketches to send the HC-SR04 readings over Wifi.
Make sure to save the sketches you wrote in stages 1 and 2 to use as test sketches later if you need to troubleshoot one of the components of your system.
I don't get it.. :frowning:
can you lookup the code please, I don't understand where to put what for esp8266 :confused:
http://projects.treadstoneweb.com/arduino/ultrasonic_sensor/UltrasonicSensor.ino
and one question, which app should I use if i want to make show data reading on my android?
Rakib475:
Please post it here.
You'll have to write your own.
It's quite simple, complete SDK and lots of info on the Internet, and it's all Java.
