I am working on a GPS data logger to SD card but need help with Arduino internal clock.
I wanted first to get a RTC circuit but want to use less components.
Is it possible to sync the arduino internal clock with the NMEA data from the GPS?
Which Arduino? What does "internal clock" mean?
Just log the GPS time to the SD card. No need to “sync” the non-existent Arduino internal clock.
The time lis logged on the SD file(RMC and GGA).
But the last edit time on the file when opend in the computer is 01.01.2000 00:00
The arduino has no system clock, so the SD library just writes some default file create time, probably zero. You will have to change your SD library to change that.
