Hi, Im an Architecture student and i've got to make a responsive machine.
My design includes a twisting surface that reacts as people walk past.
I am looking to use 2 servos to control and twist both ends of a surface and looking at using 3x IR transmitters & Receivers to trigger the servos to turn 'x' degrees when the signal is broken.
My questions are:
Is this possible to use IR transmitters & Receivers (like a sensor) to trigger a certain part of the code 'when the signal is broken'.
As in if you walk past the first set which triggers the left servo to turn 90deg;
Walk past the second set which triggers the left servo to turn another 90deg and the right servo to turn 90deg;
then walk past the third set which triggers the right servo to turn 90deg so the surface is then fully closed.
Is there any sample codes as i have never used an Arduino board or electronics before, but will be using it alot for my design module, hopefully be able to use the Firefly plugin for 3D modelling.
And if any one is able to help draw up a schematic would be MUCH appreciated.
Please email me richardpeterberry@ymail.com
Regards
Richard
