help needed - monitoring sensor and add 4 servo motor
I've already done this code for 4 PIR sensors monitoring, and now I want to add 4 servo motor to be controlled with the GUI in visual studio. how can I do this? is anybody can help me for the code? thank for your all help...
this is my code for arduino. I cant make the visual studio one..
const int sensorread = A0;
const int sensorread1 = A1;
const int sensorread2 = A2;
const int sensorread3 = A3;
pinMode(sensorread, INPUT);
pinMode(sensorread1, INPUT);
pinMode(sensorread2, INPUT);
pinMode(sensorread3, INPUT);
int counter = 0;
int counter1 = 0;
int counter2 = 0;
int counter3 = 0;
byte state;
byte state1;
byte state2;
byte state3;
byte laststate;
byte laststate1;
byte laststate2;
byte laststate3;
laststate = digitalRead(sensorread); // Pre-load last state
laststate1 = digitalRead(sensorread1);
laststate2 = digitalRead(sensorread2);
laststate3 = digitalRead(sensorread3);
Serial.println("Begin...");
unsigned long startTime = millis(); // Get current chip time
while((startTime + 30000) > millis())
if (state != laststate)
counter++; // Increments twice per drop so divide by 2 to get true count
laststate = state;
Serial.print(".");
delay (30); // Debounce
if (state1 != laststate1)
counter1++; // Increments twice per drop so divide by 2 to get true count
laststate1 = state1;
Serial.print(".");
if (state2 != laststate2)
counter2++; // Increments twice per drop so divide by 2 to get true count
laststate2 = state2;
Serial.print(".");
if (state3 != laststated3)
counter3++; // Increments twice per drop so divide by 2 to get true count
laststate3 = state3;
Serial.print(".");
char on_sensor = 'n';
if (Serial.available()>0)
on_sensor = Serial.read();
if (on_sensor == 'a')
Serial.println (counter/2);
if (on_sensor == 'b')
Serial.println (counter1/2);
if (on_sensor == 'c')
Serial.println (counter2/2);
if (on_sensor == 'd')
Serial.println (counter3/2);
That means you need visual studio code where you send command Serially to enable servo motor??
Have you checked the below code working fine or Not??
