Help needed ( newbie )
So i was compiling this program:
Hi
#include Servo.h // import the servo library
Servo myServo;
int incoming = 0;
myServo.attach(3); // initialize servo pin
myServo.write(100); // set the servo to 100 degrees
pinMode(13, OUTPUT); // set all the pins as output
Serial1.begin(9600); // connect to BT module
if(Serial1.available() > 0) // check if data is available
incoming = Serial1.read(); // read the data
digitalWrite(13, HIGH);
switch(incoming)
case 'X': // kick
myServo.write(180);
delay(750);
myServo.write(100);
SO i have a UNO and i cant use Serial1 can anyone convert it to work on UNO
(deleted)
Go read the top 3 stickies in this forum then come back here.
Apply what you learned there and you'll go far.
