Help Needed Please! I'm New To Coding and am Trying to Figure Something Out!
Hi! I'm trying to create a project that I found online and am finding myself needing to add a piece of code to this project to make it work for what I am trying to do. This code is for an LCD game where the character jumps over obstacles whenever you press a button. The game is working great, however, when I add the bit of code I had help coming up with that would give an end screen after a certain score is achieved; I get an error that says the score is not declared in this scope. I included the full code below. Could someone who is smarter than me please help?
#include <LiquidCrystal.h>
#define PIN_BUTTON 2
#define PIN_AUTOPLAY 1
#define PIN_READWRITE 10
#define PIN_CONTRAST 12
#define SPRITE_RUN1 1
#define SPRITE_RUN2 2
#define SPRITE_JUMP 3
#define SPRITE_JUMP_UPPER '.'         // Use the '.' character for the head
#define SPRITE_JUMP_LOWER 4
#define SPRITE_TERRAIN_EMPTY ' '      // User the ' ' character
#define SPRITE_TERRAIN_SOLID 5
#define SPRITE_TERRAIN_SOLID_RIGHT 6
#define SPRITE_TERRAIN_SOLID_LEFT 7
#define HERO_HORIZONTAL_POSITION 1    // Horizontal position of hero on screen
#define TERRAIN_WIDTH 16
#define TERRAIN_EMPTY 0
#define TERRAIN_LOWER_BLOCK 1
#define TERRAIN_UPPER_BLOCK 2
#define HERO_POSITION_OFF 0          // Hero is invisible
#define HERO_POSITION_RUN_LOWER_1 1  // Hero is running on lower row (pose 1)
#define HERO_POSITION_RUN_LOWER_2 2  //                              (pose 2)
#define HERO_POSITION_JUMP_1 3       // Starting a jump
#define HERO_POSITION_JUMP_2 4       // Half-way up
#define HERO_POSITION_JUMP_3 5       // Jump is on upper row
#define HERO_POSITION_JUMP_4 6       // Jump is on upper row
#define HERO_POSITION_JUMP_5 7       // Jump is on upper row
#define HERO_POSITION_JUMP_6 8       // Jump is on upper row
#define HERO_POSITION_JUMP_7 9       // Half-way down
#define HERO_POSITION_JUMP_8 10      // About to land
#define HERO_POSITION_RUN_UPPER_1 11 // Hero is running on upper row (pose 1)
#define HERO_POSITION_RUN_UPPER_2 12 //                              (pose 2)
LiquidCrystal lcd(11, 9, 6, 5, 4, 3);
static char terrainUpper[TERRAIN_WIDTH + 1];
static char terrainLower[TERRAIN_WIDTH + 1];
static bool buttonPushed = false;
void initializeGraphics() {
  static byte graphics[] = {
    // Run position 1
    B01100,
    B01100,
    B00000,
    B01110,
    B11100,
    B01100,
    B11010,
    B10011,
    // Run position 2
    B01100,
    B01100,
    B00000,
    B01100,
    B01100,
    B01100,
    B01100,
    B01110,
    // Jump
    B01100,
    B01100,
    B00000,
    B11110,
    B01101,
    B11111,
    B10000,
    B00000,
    // Jump lower
    B11110,
    B01101,
    B11111,
    B10000,
    B00000,
    B00000,
    B00000,
    B00000,
    // Ground
    B11111,
    B11111,
    B11111,
    B11111,
    B11111,
    B11111,
    B11111,
    B11111,
    // Ground right
    B00011,
    B00011,
    B00011,
    B00011,
    B00011,
    B00011,
    B00011,
    B00011,
    // Ground left
    B11000,
    B11000,
    B11000,
    B11000,
    B11000,
    B11000,
    B11000,
    B11000,
  int i;
  // Skip using character 0, this allows lcd.print() to be used to
  // quickly draw multiple characters
  for (i = 0; i < 7; ++i) {
    lcd.createChar(i + 1, &graphics[i * 8]);
  for (i = 0; i < TERRAIN_WIDTH; ++i) {
    terrainUpper[i] = SPRITE_TERRAIN_EMPTY;
    terrainLower[i] = SPRITE_TERRAIN_EMPTY;
// Slide the terrain to the left in half-character increments
void advanceTerrain(char* terrain, byte newTerrain) {
  for (int i = 0; i < TERRAIN_WIDTH; ++i) {
    char current = terrain[i];
    char next = (i == TERRAIN_WIDTH - 1) ? newTerrain : terrain[i + 1];
    switch (current) {
      case SPRITE_TERRAIN_EMPTY:
        terrain[i] = (next == SPRITE_TERRAIN_SOLID) ? SPRITE_TERRAIN_SOLID_RIGHT : SPRITE_TERRAIN_EMPTY;
      case SPRITE_TERRAIN_SOLID:
        terrain[i] = (next == SPRITE_TERRAIN_EMPTY) ? SPRITE_TERRAIN_SOLID_LEFT : SPRITE_TERRAIN_SOLID;
      case SPRITE_TERRAIN_SOLID_RIGHT:
        terrain[i] = SPRITE_TERRAIN_SOLID;
      case SPRITE_TERRAIN_SOLID_LEFT:
        terrain[i] = SPRITE_TERRAIN_EMPTY;
bool drawHero(byte position, char* terrainUpper, char* terrainLower, unsigned int score) {
  bool collide = false;
  char upperSave = terrainUpper[HERO_HORIZONTAL_POSITION];
  char lowerSave = terrainLower[HERO_HORIZONTAL_POSITION];
  byte upper, lower;
  switch (position) {
    case HERO_POSITION_OFF:
      upper = lower = SPRITE_TERRAIN_EMPTY;
    case HERO_POSITION_RUN_LOWER_1:
      upper = SPRITE_TERRAIN_EMPTY;
      lower = SPRITE_RUN1;
    case HERO_POSITION_RUN_LOWER_2:
      lower = SPRITE_RUN2;
    case HERO_POSITION_JUMP_1:
    case HERO_POSITION_JUMP_8:
      lower = SPRITE_JUMP;
    case HERO_POSITION_JUMP_2:
    case HERO_POSITION_JUMP_7:
      upper = SPRITE_JUMP_UPPER;
      lower = SPRITE_JUMP_LOWER;
    case HERO_POSITION_JUMP_3:
    case HERO_POSITION_JUMP_4:
    case HERO_POSITION_JUMP_5:
    case HERO_POSITION_JUMP_6:
      upper = SPRITE_JUMP;
    case HERO_POSITION_RUN_UPPER_1:
      upper = SPRITE_RUN1;
    case HERO_POSITION_RUN_UPPER_2:
      upper = SPRITE_RUN2;
  if (upper != ' ') {
    terrainUpper[HERO_HORIZONTAL_POSITION] = upper;
    collide = (upperSave == SPRITE_TERRAIN_EMPTY) ? false : true;
  if (lower != ' ') {
    terrainLower[HERO_HORIZONTAL_POSITION] = lower;
    collide |= (lowerSave == SPRITE_TERRAIN_EMPTY) ? false : true;
  byte digits = (score > 9999) ? 5 : (score > 999) ? 4 : (score > 99) ? 3 : (score > 9) ? 2 : 1;
  // Draw the scene
  terrainUpper[TERRAIN_WIDTH] = '\0';
  terrainLower[TERRAIN_WIDTH] = '\0';
  char temp = terrainUpper[16 - digits];
  terrainUpper[16 - digits] = '\0';
  lcd.setCursor(0, 0);
  lcd.print(terrainUpper);
  terrainUpper[16 - digits] = temp;
  lcd.setCursor(0, 1);
  lcd.print(terrainLower);
  lcd.setCursor(16 - digits, 0);
  lcd.print(score);
  terrainUpper[HERO_HORIZONTAL_POSITION] = upperSave;
  terrainLower[HERO_HORIZONTAL_POSITION] = lowerSave;
  return collide;
// Handle the button push as an interrupt
void buttonPush() {
  buttonPushed = true;
  pinMode(PIN_READWRITE, OUTPUT);
  digitalWrite(PIN_READWRITE, LOW);
  pinMode(PIN_CONTRAST, OUTPUT);
  digitalWrite(PIN_CONTRAST, LOW);
  pinMode(PIN_BUTTON, INPUT);
  digitalWrite(PIN_BUTTON, HIGH);
  pinMode(PIN_AUTOPLAY, OUTPUT);
  digitalWrite(PIN_AUTOPLAY, HIGH);
  // Digital pin 2 maps to interrupt 0
  attachInterrupt(0/*PIN_BUTTON*/, buttonPush, FALLING);
  initializeGraphics();
  lcd.begin(16, 2);
  static byte heroPos = HERO_POSITION_RUN_LOWER_1;
  static byte newTerrainType = TERRAIN_EMPTY;
  static byte newTerrainDuration = 1;
  static bool playing = false;
  static bool blink = false;
  static unsigned int distance = 0;
  if (!playing) {
    drawHero((blink) ? HERO_POSITION_OFF : heroPos, terrainUpper, terrainLower, distance >> 3);
    if (blink) {
      lcd.print("Press Start");
    delay(250);
    blink = !blink;
    if (buttonPushed) {
      playing = true;
      distance = 0;
    return;
  // Shift the terrain to the left
  advanceTerrain(terrainLower, newTerrainType == TERRAIN_LOWER_BLOCK ? SPRITE_TERRAIN_SOLID : SPRITE_TERRAIN_EMPTY);
  advanceTerrain(terrainUpper, newTerrainType == TERRAIN_UPPER_BLOCK ? SPRITE_TERRAIN_SOLID : SPRITE_TERRAIN_EMPTY);
  // Make new terrain to enter on the right
  if (--newTerrainDuration == 0) {
    if (newTerrainType == TERRAIN_EMPTY) {
      newTerrainType = (random(3) == 0) ? TERRAIN_UPPER_BLOCK : TERRAIN_LOWER_BLOCK;
      newTerrainDuration = 2 + random(10);
      newTerrainDuration = 10 + random(10);
  if (buttonPushed) {
    if (heroPos <= HERO_POSITION_RUN_LOWER_2) heroPos = HERO_POSITION_JUMP_1;
  if (drawHero(heroPos, terrainUpper, terrainLower, distance >> 3)) {
    playing = false; // The hero collided with something. Too bad.
    if (heroPos == HERO_POSITION_RUN_LOWER_2 || heroPos == HERO_POSITION_JUMP_8) {
    } else if ((heroPos >= HERO_POSITION_JUMP_3 && heroPos <= HERO_POSITION_JUMP_5) && terrainLower[HERO_HORIZONTAL_POSITION] != SPRITE_TERRAIN_EMPTY) {
      heroPos = HERO_POSITION_RUN_UPPER_1;
    } else if (heroPos >= HERO_POSITION_RUN_UPPER_1 && terrainLower[HERO_HORIZONTAL_POSITION] == SPRITE_TERRAIN_EMPTY) {
      heroPos = HERO_POSITION_JUMP_5;
    } else if (heroPos == HERO_POSITION_RUN_UPPER_2) {
      ++heroPos;
    ++distance;
    digitalWrite(PIN_AUTOPLAY, terrainLower[HERO_HORIZONTAL_POSITION + 2] == SPRITE_TERRAIN_EMPTY ? HIGH : LOW);
  delay(100);
  if ("score" == 300) //300 is just an example
    LCD. Clear();
    LCD. Print("Congratulations");//change the message within the quotation marks
Thanks!!
please edit your post. select you code and select the </> icon
@gcjr The old code tag thing doesn't work here in the new world. In here you hit three (reverse?) accent marks at start & finish of your code blocks.
-jim lee
Did you declare the variable 'score' somewhere? I don't see it. It's hard to navigate your code because you have no indentation formatting at all. Use "auto format" in the IDE to do that.
here's an attempt. as i said, paste it, select it and select the </>
#define SPRITE_JUMP_UPPER `.' // Use the `.' character for the head
void initializeGraphics(){
    static byte graphics = {
        // Run position 1
        B01100,
        B01100,
        B00000,
        B01110,
        B11100,
        B01100,
        B11010,
        B10011,
        // Run position 2
        B01100,
        B01100,
        B00000,
        B01100,
        B01100,
        B01100,
        B01100,
        B01110,
        // Jump
        B01100,
        B01100,
        B00000,
        B11110,
        B01101,
        B11111,
        B10000,
        B00000,
        // Jump lower
        B11110,
        B01101,
        B11111,
        B10000,
        B00000,
        B00000,
        B00000,
        B00000,
        // Ground
        B11111,
        B11111,
        B11111,
        B11111,
        B11111,
        B11111,
        B11111,
        B11111,
        // Ground right
        B00011,
        B00011,
        B00011,
        B00011,
        B00011,
        B00011,
        B00011,
        B00011,
        // Ground left
        B11000,
        B11000,
        B11000,
        B11000,
        B11000,
        B11000,
        B11000,
        B11000,
    int i;
void advanceTerrain(char* terrain, byte newTerrain){
        char next = (i == TERRAIN_WIDTH-1) ? newTerrain : terrain[i+1];
        switch (current){
    byte upper, lower;
    switch (position) {
    if (upper != ' ') {
    if (lower != ' ') {
    // Draw the scene
    terrainUpper[TERRAIN_WIDTH] = `\0';
    terrainLower[TERRAIN_WIDTH] = `\0';
    char temp = terrainUpper[16-digits];
    terrainUpper[16-digits] = `\0';
    lcd.setCursor(0,0);
    terrainUpper[16-digits] = temp;
    lcd.setCursor(0,1);
    lcd.setCursor(16 - digits,0);
    lcd.print(score);
    return collide;
void buttonPush() {
void setup(){
    attachInterrupt(0/PIN_BUTTON/, buttonPush, FALLING);
    lcd.begin(16, 2);
void loop(){
    if (!playing) {
        if (blink) {
            lcd.setCursor(0,0);
        delay(250);
        blink = !blink;
        if (buttonPushed) {
            playing = true;
            distance = 0;
        return;
    if (-newTerrainDuration == 0) {
    if (buttonPushed) {
            ++heroPos;
        ++distance;
    delay(100);
    if(score == 300)//300 is just an example
        LCD. Clear();
Thanks for the quick reply! I'll do that right away!
Ok! I used auto format and am editing it now. Sorry, I am really new to this. How would I go about defining this? I would guess to use the #define, but I don't know what code to put with that if any at all. Thanks for the help! :slight_smile:
  • not sure if its the formatting, but are you using back single quotes, , to surround chars? '.' and '\0'`
  • graphics needs to be defined as an array: "graphics [] = "
  • i found "attachInterrupt (0/PIN_BUTTON/, buttonPush" which i believe should be "attachInterrup (PIN_BUTTON,", no back slashes
  • believe is lcd, not LCD
  • lcd.clear(), not LCD. Clear, w/ a space after the "."
  • lcd.print, ditto
  • and as aarg suggested, "score" needs to be defined ... int score;
I'm making those changes now! Thank you very much! How would I go about defining this. Sorry, I'm really new to this.
int score;
Ok! Adding that now!
Ok! I made all of the above listed changes. The verifier found no bugs in the code, however when I reach the designated score; nothing happens. Any ideas?
You have to make an attempt to understand the code. If it's over your head, you'll have to spend a lot of time with simpler sketches until you catch on. It's not really entirely about being smart, although that certainly helps. It's about spending the time to learn. Also we have no idea what specific changes you made, so you need to re-post the revised sketch.
Ok. Thank you for your assistance and patience. I will look into some easier sketchs and close this page.
