Help needed printing to LCD GDM1602K Xiamen Ocular
Hello guys,
I am trying to print rpm value that inputs as a pulse signal on analog pin 5.
The program:
#include <DateTime.h>
#include <LiquidCrystal.h>
int resetPin = 3; // pin 3 resets the time
volatile byte rpmcount;
unsigned int rpm;
unsigned long timeold;
//create object to control an LCD GMD1602K.
LiquidCrystal lcd(12, 11, 2, 7, 8, 9, 10);
void setup(){
digitalWrite(resetPin,HIGH); // this line enables pull-up
pinMode(13,OUTPUT); // flash the LED each second
pinMode(resetPin, INPUT); // a button on this pin resets the time
DateTime.sync( 0 ); // set time to zero
/* ------Counts & prints rpm (adapted from Arduino Forum) ---------/
if (rpmcount >= 20) { //Update RPM every 20 counts, increase this for better RPM resolution,
//decrease for faster update
rpm = 30
1000/(millis() - timeold)*rpmcount;
timeold = millis();
rpmcount = 0;
lcd.setCursor(0,0);
lcd.print(“rpm”);
lcd.print(" “);
lcd.setCursor(4,0);
lcd.print(rpm);
lcd.print(” ");
void rpm_fun()
rpmcount++;
//Each rotation, this interrupt function is run twice
Sympthoms:
No result is printed, even the label “rpm” is not printed.
Any solutions ?
Thank you.
Old Beaver
Does "rpmcount" ever exceed 19? You're also missing a "}" somewhere before "void rpm_fun".
Some code is missing from the sketch you posted. rpm_fun is never called. Try this to see if you get anything on the lcd. And add in the code that wull call rpm_fun
volatile byte rpmcount =20;
 unsigned int rpm;
/* ------Counts & prints rpm (adapted  from Arduino Forum) ---------*/
    rpm = 30*1000/(millis() - timeold)*rpmcount;
    timeold = millis();
    rpmcount = 0;
    lcd.setCursor(0,0);
    lcd.print("rpm");
    lcd.print(" ");
    lcd.setCursor(4,0);
    lcd.print(rpm);
    lcd.print(" ");
void rpm_fun()
  rpmcount++;
Dear Mem,
This is the contents of the missing function:
void rpm_fun() {
//Each rotation, this interrupt //function is run twice, so take //that into consideration for //calculating RPM //Update count rpmcount++;
//Toggle status LED if (status == LOW) { status = HIGH; } else { status = LOW; } digitalWrite(statusPin, status); }
This function is called only once in Void Setup as follows:
attachInterrupt(0, rpm_fun, FALLING);
I missed it, so I will check myself too. :-?
Thank you,
Old Beaver
AWOL,
Tks, I will check that too.
Old Beaver
Thank you folks !! :)
The program is workin OK.
Tomorrow I will test with real car inputs.
Good programming,
Old Beaver
