Hello,
I am having a problem with running arduino and complie my java code
I using netbeans to to have access to the ttyUSB0
it works fine from the first time then if I stop and do it again it will give this following problem
Exception in thread "main" gnu.io.NoSuchPortException
at gnu.io.CommPortIdentifier.getPortIdentifier(CommPortIdentifier.java:269)
at tester.Main.main(Main.java:27)
Java Result: 1
BUILD SUCCESSFUL (total time: 0 seconds)
the only way I can debug again by restarting my ubuntu 9.04 32bit
and run arduino and make the upload then close it then run netbeans then run the java program
I am sure why this ttyUSB port not found.
is it may the port is unlocked from the previous run
I also noticed that the the previous sketch was still there
even I made another upload(it was successful ) using another computer.
its maybe the memory is not cleared and that why I cannot establish any communication
I am using arduino NG or older with ATmega168
thanks
