xmbx26
August 24, 2024, 7:49pm
1
Hello everyone,
I need assistance with reading data from a GoodWe Smartmeter GW3000 via the RS485 interface using an Arduino Uno and a MAX485 module. My goal is to read the watt data from the smart meter. Here is my current setup and the code I have so far:
Schematic:
**1.Arduino Uno:**
RX (Pin 0) -> DI (MAX485)
TX (Pin 1) -> RO (MAX485)
GND -> GND (MAX485)
5V -> VCC (MAX485)
DE and RE (MAX485) -> Pin 2 (Arduino, for control)
**MAX485 Module:**
A -> RS485 A (Smartmeter)
B -> RS485 B (Smartmeter)
GND -> GND (Smartmeter)
Code:
#include <ModbusMaster.h>
ModbusMaster node;
void preTransmission() {
digitalWrite(2, HIGH);
void postTransmission() {
digitalWrite(2, LOW);
pinMode(2, OUTPUT);
node.begin(1, Serial);
node.preTransmission(preTransmission);
node.postTransmission(postTransmission);
uint8_t result;
uint16_t data[6];
result = node.readInputRegisters(0x0000, 6);
if (result == node.ku8MBSuccess) {
for (int i = 0; i < 6; i++) {
data[i] = node.getResponseBuffer(i);
Serial.print("Watt: ");
Serial.println(data[0]);
Serial.print("Error: ");
Serial.println(result);
Thank you in advance for any suggestions or guidance!
kmin
August 24, 2024, 7:54pm
2
You can't use same serial for serial monitor and rs485. If you are limited to use arduino uno, you need to use softwareserial for rs485.
xmbx26
August 24, 2024, 8:03pm
4
Like this?
#include <SoftwareSerial.h>
// Definiere die Pins für SoftwareSerial (MAX485)
SoftwareSerial max485Serial(10, 11); // RX, TX
while (!Serial) {
; // Warte auf die serielle Verbindung
max485Serial.begin(9600);
Serial.println("Smart Meter Goodwe GM3000 Initialisierung...");
if (max485Serial.available()) {
String data = max485Serial.readStringUntil('\n');
Serial.println("Empfangene Daten: " + data);
if (Serial.available()) {
String debugData = Serial.readStringUntil('\n');
max485Serial.println("Debug: " + debugData);
kmin
August 24, 2024, 8:11pm
5
Try with that, for sure you don't get any modbus communication.
Show your wiring.
Code would be like this.
// Define software serial RX and TX pins
#define RX_PIN 2
#define TX_PIN 3
#define MAX485_DE_RE 4
// Create a SoftwareSerial instance
SoftwareSerial mySerial(RX_PIN, TX_PIN);
ModbusMaster node;
digitalWrite(MAX485_DE_RE, 1);
digitalWrite(MAX485_DE_RE, 0);
pinMode(MAX485_DE_RE, OUTPUT);
mySerial.begin(9600); // Initialize software serial port
node.begin(1, mySerial); // Use software serial for Modbus communication
uint8_t result;
result = node.readInputRegisters(0x0000, 2);
Serial.print("1st reg: ");
Serial.println(node.getResponseBuffer(0));
Serial.print("2nd reg: ");
Serial.println(node.getResponseBuffer(1));
Serial.print("Modbus Error: ");
Serial.println("\n ------------ \n ");
and post your modbus protocol sheet.
xmbx26
August 24, 2024, 8:20pm
6
Like your code so:
Arduino Uno MAX485 Modul
5V ----------------> VCC
GND ----------------> GND
2 (RX_PIN) --------> RO
3 (TX_PIN) --------> DI
4 (MAX485_DE_RE) --> DE
4 (MAX485_DE_RE) --> RE
A ------------------> A (RS485 Bus)
B ------------------> B (RS485 Bus)
xmbx26
August 24, 2024, 8:24pm
7
now i have a modus 226 error
kmin
August 24, 2024, 8:28pm
8
It means, you have no response.
Post a photo of your wiring and gw3000 modbus protocol.
xmbx26
August 24, 2024, 8:29pm
9
My Setup looks like this.
xmbx26
August 24, 2024, 8:31pm
10
Thats the problem i know only it has rs485 and no protocol i hope that is the same like outher smart meters.
kmin
August 24, 2024, 8:40pm
11
Then post a protocol "of your hope". And a photo that we can see clearly wiring between arduino and rs485 module.
xmbx26
August 24, 2024, 9:00pm
12
I post it tomorow i am Not in the Workshop anymore
xmbx26
August 25, 2024, 9:51am
13
I have it like this and i know it uses modbus and i need to read the regsiter 35172.
#define RX_PIN 2
#define TX_PIN 3
ModbusMaster node;
uint8_t result;
// Read register at address 35172 (0x8974)
result = node.readInputRegisters(0x8974, 2);
kmin
August 25, 2024, 1:35pm
14
From where you got that register address?
in five digit modbus numbering system 35172 means input register nro 5172 (first reg is 30001). That would be 0x1433 in hex.
kmin
August 25, 2024, 1:57pm
15
Your wiring looks correct, but jumper wires and breadboard is bringing reliability next to nothing. So we don't know if that part is ok.
If expect that your problem is not right register address. If that device respect modbus standard, it should give response even if that register is empty or not allowed.
So I think that you have wrong slave address or hardware problem.
Edit:
I did quick research and found tiny evidence that slave address could be 3.
xmbx26
August 25, 2024, 3:06pm
16
I have the register from this german page.
Da ich mich nun schon länger mit der Einbindung der Goodwe Wechselrichter per Modbus TCP beschäftige, und ich ebenfalls von der IoBroker Community viel Hilfe, Scripte oder Adapter nutze, möchte ich meine Erfahrungen mit euch teilen. Grundlegen sind...
kmin
August 25, 2024, 4:01pm
19
The registers in your link were from inverter, not from meter.
Did I understand correctly that you try to read the meter?
Like this:
As long as error is 226, you have no communication.
xmbx26
August 25, 2024, 4:07pm
20
Yes i want to read a smart meter like this.
kmin
August 25, 2024, 4:12pm
21
Let's try to follow that tiny evidence I found.
Slave 3 and read holding regs instead of input.
#define RX_PIN 2
#define TX_PIN 3
ModbusMaster node;
node.begin(3, mySerial); // Use software serial for Modbus communication
uint8_t result;
uint8_t j;
result = node.readHoldingRegisters(0x005E, 10);
for (j = 0; j < 10; j++)
Serial.println(node.getResponseBuffer(j));
xmbx26
August 25, 2024, 5:21pm
22
I tryied this code and i have also error 226 ):
