help needed setting up an arduino and imu
hello all,
I am starting my senior ME project (the team is building formation flying quad copters) and am foreign to the world of ardiunos. I bought a arduino mega ( http://www.sparkfun.com/products/11061 ) and a imu stick (http://www.sparkfun.com/products/10183) to measure position and orientation. There are four pin holes one the imu labeled; scl, sda, gnd, and vcc. I was able to find the gnd means ground, vcc is voltage and the stick needs 3.3v ( i think), scl is the clock, and sda is the data from the IMU.
I am unsure how to connect the imu to the arduino and how to view the readings on my computer.
Also there will be two cs/ee guys joining us in the fall.
Thanks
Welcome to the Arduinoworld
SCL SDA indicate I2C bus, you need to read about these commands - http://www.arduino.cc/en/Reference/Wire -
an in depth description - http://www.gammon.com.au/forum/?id=10896 -
thanks
