Help needed simplifying graphing consecutive lines w/Processing 2.0.2
Hello. I am graphing consecutive lines with Procesing 2.0.2 using gyro's coordinates (x,y) and encoder's distances (d), both via Xbee from an Arduino Fio. i.e:
line 1: x1,y1 ----d1---- x2,y2 line 2: x2,y2 ----d2---- x3,y3 line 3: x3,y3 ----d3---- x4,y4 etc...
So far my application works OK but as the amount of lines (coordinates and distances) increase, my code is getting bigger and bigger. I need help trying to simplify the code (may be using 'for' or 'while' iterations). x and y are proportional to the distance and they become xn and yn after the distance and the second point are fixed. Here my draw() function for the first four lines.Thank you.
void draw() {
  background(255);
  translate(width/2, height/2);;
  // First concatenated line (not yet fixed)
  if(fixed_lines==0){
  line(0,0,x,y);
  // concatenated lines 1 and 2 (line 1 fixed)
  if(fixed_lines==1){
  line(0,0,x1,y1);
  line(x1,y1,x1+x,y1+y);
  // concatenated lines 1, 2 and 3 (lines 1 and 2 fixed)
  if(fixed_lines==2){
  line(0,0,x1,y1);
  line(x1,y1,x2,y2);
  line(x2,y2,x2+x,y2+x);
  // concatenated lines 1, 2, 3 and 4 (lines 1, 2 and 3 fixed)
  if(fixed_lines==3){
  line(0,0,x1,y1);
  line(x1,y1,x2,y2);
  line(x2,y2,x3,y3);
  line(x3,y3,x3+x,y3+y);
