Help Needed to Connect Arduino Leonardo with HanRun HR911105A 22/02 (W5500)
Hello everyone,
I'm currently working on a project that involves connecting an Arduino Leonardo with a HanRun HR911105A 22/02 (W5500 Ethernet module). I've made the following connections, but I'm having trouble getting it to work correctly.
Here are the connections I have made:
HanRun HR911105A (W5500)      Arduino Leonardo
_________________________      _______________________
| SCLK             -       |----| Digital Pin xx        |
| MOSI            MOSI (11)|----| Digital Pin 11 (MOSI)|
| MISO            MISO (12)|----| Digital Pin 12 (MISO)|
| SCS (CS)        10        |----| Digital Pin 10 (SS)  |
| INT             7         |----| Digital Pin 7        |
| RST             8         |----| Digital Pin 8        |
| 3.3V            3.3V/5V   |----| 3.3V or 5V           |
| GND             GND       |----| GND                   |
|_________________________|    |_______________________|
I've tried using the Ethernet library, but I can't seem to establish a connection. Does anyone have experience with this setup or any suggestions on what I might be doing wrong?
#include <SPI.h>
#include <Ethernet_Generic.h>
const int chipSelect = 10;
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192, 168, 0, 177);
EthernetServer server(80);
  Ethernet.begin(mac, ip);
  while (!Serial) {
  if (Ethernet.hardwareStatus() == EthernetNoHardware) {
    Serial.println("Ethernet shield was not found.");
    while (true) {
      delay(1);
  if (Ethernet.linkStatus() == LinkOFF) {
    Serial.println("Ethernet cable is not connected.");
  Serial.print("IP Address: ");
  Serial.println(Ethernet.localIP());
  server.begin();
  if (client) {
    Serial.println("New client");
    client.println("Content-type:text/html");
    client.println("Connection: close");
    client.println();
    client.println("<!DOCTYPE HTML>");
    client.println("<html>");
    client.println("<head><title>HELLO</title></head>");
    client.println("<body>");
    client.println("<h1>HELLO</h1>");
    client.println("</body>");
    client.println("</html>");
    delay(1);
    client.stop();
    Serial.println("Client disconnected");
when using SPI on a Leonardo I used the pins on the ICSP connector, e.g. for a RFM95
  // Leonardo connections
// Leonardo ICSP SCK  pin 15  to RFM95 SCK
// Leonardo ICSP MISO pin 14  to RFM95 MISO
// Leonardo ICSP MOSI pin 16   to RFM95 MOSI
// Leonardo pin 2 to RFM95 SS
// Leonardo pin 3 to RFM95 Reset
// Leonardo pin 4 to RFM95 DIO0
// Leonardo GND and 3.3V to RFM95
what displayed on the serial monitor?
