#include <Adafruit_Fingerprint.h>
#include <SPI.h>
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
#include<LiquidCrystal_I2C.h>
SoftwareSerial SIM800(10,11);
#define gps Serial3
#define mySerial Serial1
#define I2C_ADDR 0x27
#define BACKLIGHT_PIN 3
#define En_pin 2
#define Rw_pin 1
#define Rs_pin 0
#define D4_pin 4
#define D5_pin 5
#define D6_pin 6
#define D7_pin 7
LiquidCrystal_I2C lcd(I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin); //LCD declaring
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
static const uint32_t GPSBaud = 9600;
int relayPin = 8;
//String str="";
char str[70];
String gpsString="";
char *test="$GPGGA";
String latitude="No Range ";
String longitude="No Range ";
int temp=0,i;
boolean gps_status=0;
pinMode(relayPin, OUTPUT);
digitalWrite(relayPin, HIGH);
SIM800.begin(9600);
while (!SIM800);
delay(100);
lcd.begin(16,2);
lcd.setBacklightPin(BACKLIGHT_PIN,POSITIVE);
lcd.setBacklight(HIGH);
lcd.setCursor(0, 0);
lcd.print("Smart Safe Sahan");
lcd.setCursor(0, 1);
lcd.print("Chandimal");
delay(5000);
lcd.clear();
// set the data rate for the sensor serial port
Serial1.begin(9600);
finger.begin(57600); //Sensor baude rate
lcd.begin (16,2);
lcd.home ();
finger.getTemplateCount(); //Counts the number of templates stored in the sensor flash memory
lcd.setCursor(0,0);
lcd.print("Scan ready");
lcd.clear();
Serial3.begin(9600);
gps.begin(GPSBaud);
lcd.print("Ammo Tracking");
lcd.setCursor(0,1);
lcd.print(" System ");
delay(2000);
SIM800_init();
lcd.clear();
SIM800.println("AT+CNMI=2,2,0,0,0");
lcd.print("GPS Initializing");
lcd.setCursor(0,1);
lcd.print(" No GPS Range ");
get_gps();
delay(2000);
lcd.clear();
lcd.print("GPS Range Found");
lcd.setCursor(0,1);
lcd.print("GPS is Ready");
delay(2000);
lcd.clear();
lcd.print("System Ready");
temp=0;
serialEvent();
if(temp)
get_gps();
tracking();
void serialEvent()
while(SIM800.available())
if (SIM800.find("RING"))
temp=1;
lcd.print("SMS received");
temp=0;
void gpsEvent()
gpsString="";
while(1)
while (gps.available()>0) //checking serial data from GPS
char inChar = (char)gps.read();
gpsString+= inChar; //store data from GPS into gpsString
i++;
if (i < 7)
if(gpsString[i-1] != test[i-1]) //checking for $GPGGA sentence
i=0;
gpsString="";
if(inChar=='\r')
if(i>65)
gps_status=1;
i=0;
if(gps_status)
void SIM800_init()
lcd.clear();
lcd.print("Finding Module..");
boolean at_flag=1;
while(at_flag)
SIM800.println("AT");
while(SIM800.available()>0)
if(SIM800.find("OK"))
at_flag=0;
lcd.clear();
lcd.print("Module Connected..");
lcd.clear();
lcd.print("Disabling ECHO");
boolean echo_flag=1;
while(echo_flag)
SIM800.println("ATE1");
SIM800.println("AT+CGATT=1");
SIM800.println("AT+SAPBR=3,1,\"CONTYPE\",\"GPRS\" ");
SIM800.println("AT+SAPBR=3,1,\"APN\",\"RCMNET\" ");
SIM800.println("AT+SAPBR=1,1");
echo_flag=0;
lcd.clear();
lcd.print("Echo OFF");
lcd.clear();
lcd.print("Finding Network..");
boolean net_flag=1;
while(net_flag)
{ SIM800.println("ATE0");
SIM800.println("AT+CPIN?");
if(SIM800.find("+CPIN: READY"))
net_flag=0;
delay(4000);
lcd.clear();
lcd.print("Network Found..");
lcd.clear();
void get_gps()
gps_status=0;
int x=0;
while(gps_status==0)
gpsEvent();
int str_lenth=i;
latitude="";
longitude="";
int comma=0;
while(x<str_lenth)
if(gpsString[x]==',')
comma++;
if(comma==2) //extract latitude from string
latitude+=gpsString[x+1];
else if(comma==4) //extract longitude from string
longitude+=gpsString[x+1];
x++;
int l1=latitude.length();
latitude[l1-1]=' ';
l1=longitude.length();
longitude[l1-1]=' ';
lcd.clear();
lcd.print("Lat:");
lcd.print(latitude);
lcd.setCursor(0,1);
lcd.print("Long:");
lcd.print(longitude);
i=0;x=0;
str_lenth=0;
delay(2000);
void init_sms()
SIM800.println("AT+CMGF=1");
SIM800.println("AT+CMGS=\"+94779994223\""); // use your 10 digit cell no. here
void send_data(String message)
SIM800.println(message);
delay(200);
void send_sms()
SIM800.write(26);
void lcd_status()
lcd.clear();
lcd.print("Message Sent");
delay(2000);
lcd.clear();
return;
void tracking()
init_sms();
send_data("Locker Tracking Alert:");
send_data("Your Locker's Current Location:");
SIM800.print("Latitude:");
send_data(latitude);
SIM800.print("Longitude:");
send_data(longitude);
send_data("Please take some action soon..\nThankyou");
send_sms();
delay(2000);
lcd_status();
WIth the below one, this is for the fingerprint reader, should be placed inside the void loop().
void fn()
getFingerprintIDez();
int getFingerprintIDez() {
uint8_t p = finger.getImage();
if (p != FINGERPRINT_OK) {
lcd.print(" Scanner ready");
return -1;
p = finger.image2Tz();
lcd.clear();
lcd.print(" Messy Image");
lcd.print(" Try Again");
delay(3000);
lcd.clear();
return -1;
p = finger.fingerFastSearch();
lcd.clear();
lcd.print("Not a valid Finger");
delay(3000);
lcd.clear();
return -1;
// found a match!
lcd.clear();
lcd.print(" Door Unlocked");
lcd.print(" Welcome");
digitalWrite(relayPin, LOW);
delay(3000);
lcd.clear();
return finger.fingerID;
Can anyone help?
