J4YMF
#1
hello folks
im after some help understanding loops.
if i want to run this loop two times then changes to another loop how do i go about doing that?
#include <MegaServo.h>
MegaServo digger ;
MegaServo dig ;
MegaServo up ;
MegaServo down ;
int pos = 0;
digger.attach(8);
up.attach(9);
down.attach(10);
dig.attach(11);
for(pos = 75; pos < 120; pos += 1)
digger.write(pos);
delay(40);
for(pos = 130; pos>= 90; pos-= 1) //up
up.write(pos);
delay(100);
system
#2
I for one, would need a bit more information.
Are you talking about the void loop(), or the for( ; ; ) loops?
J4YMF
#3
sorry alphabeta
i meant to say the void loop()
jason
system
#4
No need to apologize
Anyways. One way you could do it:
byte currentLoop = 0;
byte loop1Counter = 0;
byte loop2Counter = 0;
void loop(){
switch (currentLoop){
case 0: loop1(); break;
case 1: loop2(); break;
void loop1(){
loop1Counter++;
if (loop1Counter==2){loop1Counter=0; currentLoop = 1;}
//do code
void loop2(){
loop2Counter++;
if (loop2Counter==2){loop2Counter=0; currentLoop = 0;}
//do code
J4YMF
#5
many thanks
i will have a play.
do i place this at the top of my code like this ?.
MegaServo digger ;
MegaServo dig ;
MegaServo up ;
MegaServo down ;
int pos = 0;
digger.attach(8);
up.attach(9);
down.attach(10);
dig.attach(11);
void loop(){
void loop1(){
loop1Counter++;
//do code
void loop2(){
loop2Counter++;
//do code
void loop1()
digger.write(pos);
delay(40);
up.write(pos);
delay(100);
jason = newbie
system
#6
You have two cases of loop1(), remove both, and replace with this:
void loop1()
loop1Counter++;
//do code
digger.write(pos);
delay(40);
up.write(pos);
delay(100);
[edit]What are you trying to do? Or rather… What are you making?[/edit]
J4YMF
#7
i c
i understand now, not sure what you meant by // do code
but i do now
many thanks jason
im making a model digger for my oo scale railway
An Arduino controlled digger! Coooooolll !! Please post a video once you get it work
