So, I got 1 button and a servo.
Now when I press and hold the button I want the servo to move a number of steps and then stop as long as the button is pressed.
Once the button is released it needs to go back the same numbers of steps to get to the original location.
I tried a bunch of stuff.
Make it move in void setup() instead of in void loop(), for ()....
But not giving the effect I want.
#include <Servo.h>
Servo servoUD; // create servo object to control a servo
int angleUD = 90;
int angleStepUD = 1;
int i;
#define Backup 8
servoUD.attach(10);
pinMode(Backup, INPUT_PULLUP);
servoUD.write(angleUD);
Serial.println("************************************************");
while (digitalRead(Backup) == LOW) {
if (angleUD > 20 && angleUD <= 160) {
angleUD = angleUD - angleStepUD;
if (angleUD < 20) {
angleUD = 20;
for (i = 0; i < 10; i++) {
servoUD.write(angleUD); // move the servo to desired angle
Serial.print("Moved DS north to: ");
Serial.print(angleUD); // print the angle
Serial.println("°");
delay(100);
delay(10000); // waits for the servo to get there
while (digitalRead(Backup) == HIGH) {
if (angleUD >= 20 && angleUD <= 160) {
angleUD = angleUD + angleStepUD;
if (angleUD > 160) {
angleUD = 160;
Serial.print("Moved DS south to: ");
delay(100);
What does it do that it shouldn't ?
Why the 10 second delay()s ?
I am very new to Arduino so I am just copy pasting parts of code I find and adjusting them.
The 10 second delay was just an effort to make it stop looping.
It needs to loop to read the button press/release, but as long as the button is pressed it only needs to do 10 steps.
I cant get it to stop looping those 10 steps.
You need to detect when the button becomes pressed then run the for loop. Note the need to detect when the button becomes pressed rather than when it is pressed
See the StateChangeDetection example in the IDE
Thanks, thats what I needed.
The code now looks like this:
#include <Servo.h>
int angleUD = 90;
int i;
int buttonState = 0;
int lastButtonState = HIGH;
#define backUp 8
#define ledPin 13
servoUD.attach(10);
pinMode(backUp, INPUT_PULLUP);
// read the pushbutton input pin:
buttonState = digitalRead(backUp);
// compare the buttonState to its previous state
if (buttonState != lastButtonState) {
// if the state has changed, increment the counter
if (buttonState == LOW) {
// if the current state is HIGH then the button went from off to on:
digitalWrite(ledPin, HIGH);
Serial.println("on");
for (i=0;i<10;i++){
servoUD.write(angleUD = angleUD - angleStepUD); // move the servo to desired angle
Serial.print("Moved DS South to: ");
delay(100); // waits for the servo to get there
// if the current state is LOW then the button went from on to off:
digitalWrite (ledPin, LOW);
Serial.println("off");
for (i=0;i<10;i++){
servoUD.write(angleUD = angleUD + angleStepUD); // move the servo to desired angle
// Delay a little bit to avoid bouncing
delay(100);
// save the current state as the last state, for next time through the loop
lastButtonState = buttonState;
I'm glad it works and I am sure that you will use the technique again in future
It does not matter to the compiler but some of the comments do not match the code. This may be confusing if you need to refer to this code when using the technique in future
