the whole point of this system is the have the right camera turned on depending on which microphones are on. I managed to get this working yesterday afternoon before i saw your reply but ill explain it all anyway and maybe you guys can help me clean it up a bit.
there is 3 cameras and 1 still screen (which is just our logo for when we are not broadcasting from our studios eg: football game.)
the still screen is activated when no microphones are turned on.
i changed the input pull-up issue.
4.the reason the guest cam needs 2 switches is sometimes we have a guest on mic 3, other times mic 4 and sometimes both. (if there is a way to combine that into 1 switch that would be great)
- i figured out that the final line with all the &&'s could be taken out and should just say "else" instead.
here is the current code that is working when i test it but would like to make sure its okay before trying to install it.
livestream cam draft
this will switch betweencams facing either the annoucer, guest, news or still screen.
int Cam1 = 3;
int Cam2 = 4;
int NewsCam = 5;
int StillScreen = 6;
int Mic1 = 8;
int Mic3 = 9;
int Mic4 = 10;
int NewsMic = 11;
void setup(){
//set cams and stillscreans to outputs
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
// Enable internal pull-up resistor
pinMode(8, INPUT_PULLUP);
pinMode(9, INPUT_PULLUP);
pinMode(10, INPUT_PULLUP);
pinMode(11, INPUT_PULLUP);
//begin checks for mics
if(digitalRead(11) == LOW)
digitalWrite(NewsCam, HIGH); //turns on cam in newsroom
digitalWrite(Cam1, LOW);
digitalWrite(Cam2, LOW);
digitalWrite(StillScreen, LOW);
else if (digitalRead(10) == LOW)
digitalWrite(Cam2, HIGH); //turns on guest cam
digitalWrite(NewsCam, LOW);
else if (digitalRead(9) == LOW)
else if (digitalRead(8) == LOW)
digitalWrite(Cam1, HIGH); //turns on talent cam
digitalWrite(StillScreen, HIGH); //turns on stillscreen
