Help needed with 'Case' writing
Hi everyone. i've a project i'm working on with servos, an ultrasonic sensor and some other bits an pieces. there's a part of the code where if something comes up close to the sensor, the servos react to it. i'm wanting to add a choice between three different actions here. i'm under the impression i can do this using 'case' but i've never used it before, and i'm a bit stumped on how to implement it.
I've had a google and can't really find how to fit existing projects to my needs.
Any pointers would be great!
The part i'm wanting to add to is labelled //THIS IS WHERE I WANT THE CHOICE!!
and is about 1/3 of the way down the code.
#include "SoftwareSerial.h"
#include "DFRobotDFPlayerMini.h"
// Use pins 2 and 3 to communicate with DFPlayer Mini
static const uint8_t PIN_MP3_TX = 9; // Connects to module's RX
static const uint8_t PIN_MP3_RX = 10; // Connects to module's TX
SoftwareSerial softwareSerial(PIN_MP3_RX, PIN_MP3_TX);
// Create the Player object
DFRobotDFPlayerMini player;
#include <Servo.h>  //arduino library
#include <math.h>   //standard c librarz
int Reset = 3;
Servo baseServo;
Servo arielServo;
Servo tiltServo;
struct headPos {
  int baseServoAngle;
  int arielServoAngle ;
  int tiltServoAngle ;
  int desiredDelay ;
struct headPos faceMotion;
#define echoPin A2 // Echo Pin
#define trigPin A3 // Trigger Pin
//int desiredDelay = 16;
int ready = 0;
int randomNumber = 0;
// Define the default startup mode
int  robotMode = 700;
int buzzerTone = 500;
//+++++++++++++++ULTRASONIC VARIABLES++++++++++++++++++++++++++++
#define buzzerPin 10        // Pin for the buzzer
bool holder = 1;
int maximumRange = 200;     // Maximum range needed
int minimumRange = 0;       // Minimum range needed
long readDistance;          // the output distance from the sensor
//+++++++++++++++FUNCTION DECLARATIONS+++++++++++++++++++++++++++
int ultraSensor(int theEchoPin, int theTrigPin);
void moveTo( struct headPos faceMotion);
void Speak3 (int soundPin, int currentTone, int finalTone);
void storedAction(int positionSelected, int theSpeed);
void speakWalter (int soundPin, int maxWords);
int servoParallelControl (int thePos, Servo theServo, int theSpeed );
void generateAction();
digitalWrite(Reset, HIGH);
  delay(200);
  pinMode(Reset, OUTPUT);
  softwareSerial.begin(9600);
  Serial.println("Beginning bootup protocols.");
  delay(200);
  digitalWrite(Reset, LOW);
  delay(200);
  if (player.begin(softwareSerial)) {
    Serial.println("Vocal Module Engaging...");
    player.volume(20);              ////////////////////////////////////////////////////////////////////////////////////////////////////VOLUME!!!!!
    baseServo.attach(2);
  arielServo.attach(4);
  tiltServo.attach(3);
  baseServo.write(90);        //intial positions of servos
  arielServo.write(90);
  tiltServo.write(90);
    delay (3000);
    player.playMp3Folder(0001);
    delay (4000);
    Serial.println("Vocal Module Engaged");
    Serial.println("Vocal Module Failed to Engage");
  Serial.setTimeout(50);      //ensures the the arduino does not read serial for too long
  Serial.println("Cognitive functionality operating as expected.");
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  pinMode(buzzerPin, OUTPUT);
  ready = 0;
  noTone(buzzerPin);
  // read a usb command if available
  if (Serial.available()) {
    // read what type of a command will be sent
    robotMode = Serial.parseInt();
    if (robotMode == 200) {
      faceMotion.baseServoAngle = Serial.parseInt();
      faceMotion.arielServoAngle = Serial.parseInt();
      faceMotion.tiltServoAngle = Serial.parseInt();
      //buzzerTone = Serial.parseInt();
      if (Serial.read() == '\n') {            // if the last byte is 'd' then stop reading and execute command 'd' stands for 'done'
        Serial.flush();                     //clear all other commands piled in the buffer
        Serial.println('d');                  //send completion of the command
  //++++++++++++++++Decision of process to use+++++++++++++++++++++++++++
  if (robotMode == 500) {
    //Go Compeletely Silent
  if (robotMode == 600) {
    // Alarm Sequence
    tone(buzzerPin, 1000);
    //delay(5000);
    noTone(buzzerPin);
  if (robotMode == 700) {
    //Normal Interaction Mode
    Serial.println("Observing...");                  //send completion of the command
    //read the distance read by the sensor
    readDistance = ultraSensor(echoPin, trigPin);
    if (readDistance >= 30) {
      int nothingCount = 0;
      generateAction();
      //Check an area in the map
      //this is where all the fun starts
      randomNumber = random(1, 6); // find a random whole number between the two values
      int randomIterations = random (1,5);
      //Serial.println(randomNumber);
      //run through s set of random actions
      int i;
      for (i=1; i<randomIterations; i++){
        generateAction();
      //storedAction(randomNumber, 2);
    else { /////////////////////////////////////////////////////////////////////////////////////////////////////THIS IS WHERE I WANT THE CHOICE!!
  } // end of 700 if mode
  // ---------------------------------------Act Upon Mode Type---------------------------------------------
  //  //++++++++++++++++++Remote Mode++++++++++++++++++++++
  //  if (robotMode == 200) {
  //    //faceMotion.base
  //    tone(buzzerPin, buzzerTone);
  //    moveTo(faceMotion );
  //    //servoParallelControl ( baseServoAngle, baseServo, 5 );
  //  // ++++++++++++++++Speech Mode+++++++++++++++++++++
  //  if (robotMode == 600) {
  //    //speakWalter(buzzerPin, 50);
  //  // ++++++++++++++++Stopped Mode+++++++++++++++++++++
  //  if (robotMode == 700) {
} // end of primary loop
//++++++++++++++++++++++++++++++FUNCTION DEFINITIONS++++++++++++++++++++++++++++++++++++++++++
int ultraSensor(int theEchoPin, int theTrigPin) {
  //this fucntion caluclates and returns the distance in cm
  long duration, distance; // Duration used to calculate distance
  /* The following trigPin/echoPin cycle is used to determine the
    distance of the nearest object by bouncing soundwaves off of it. */
  digitalWrite(theTrigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(theTrigPin, HIGH);
  delayMicroseconds(10);
  duration = pulseIn(theEchoPin, HIGH);
  //Calculate the distance (in cm) based on the speed of sound.
  distance = duration / 58.2;
  return distance;
void speakWalter (int soundPin, int maxWords) {
  int toneDuration;
  int numberOfWords;
  int toneFreq;     // frequency of tone created
  int phraseDelay;  // the time between individual statements
  numberOfWords = random (1, maxWords);
  //Serial.print("Number of words = ");
  //Serial.println(numberOfWords);
  // generate the random set of words
  for ( int i; i <= numberOfWords; i++) {
    toneDuration = random (25, 300);
    toneFreq = random (200, 400);
    tone(soundPin, toneFreq);
    delay(toneDuration);
    noTone(soundPin);
  //phraseDelay = random(100, 10000);
  //delay(phraseDelay);
  //noTone(soundPin);
void Speak2 (int soundPin, int maxWords, Servo Rot1, Servo Nod1, Servo Tilt1) {
  //function that links servo motion to sound
  int toneDuration;
  int numberOfWords;
  int toneFreq;
    // randomly generate the tone durations and freq
    toneDuration = random (25, 150);
    toneFreq = random (100, 1800);
    // use the tone durations to define servo movemnt
    //large number of tones
    noTone(soundPin);
void Speak3 (int soundPin, int currentTone, int finalTone) {
  // has two notes meld into each other as a singer might
  int toneDuration = 8;
  //int numberOfWords;
  //int toneFreq;     // frequency of tone created
  //int phraseDelay;  // the time between individual statements
  //numberOfWords = random (1,maxWords);
  int theDiff = (finalTone - currentTone) / 5; //The difference between the values
  if (theDiff > 0) {
    // if ascending
    for ( int i; i <= theDiff; i++) {
      tone(soundPin, currentTone);
      currentTone = currentTone + 5;
      noTone(soundPin);
    noTone(soundPin);
  else {
    theDiff = abs(theDiff);
      currentTone = currentTone - 5;
      noTone(soundPin);
    noTone(soundPin);
void moveTo( struct headPos faceMotion) {
  int status1 = 0;
  int status2 = 0;
  int status3 = 0;
  int done = 0 ;
  while ( done == 0) {
    //move the servo to the desired position
    //this loop will cycle through the servos sending each the desired position.
    //Each call will cause the servo to iterate about 1-5 degrees
    //the rapid cycle of the loop makes the servos appear to move simultaneously
    status1 = servoParallelControl(faceMotion.baseServoAngle, baseServo, faceMotion.desiredDelay);
    status2 = servoParallelControl(faceMotion.arielServoAngle, arielServo, faceMotion.desiredDelay);
    status3 = servoParallelControl(faceMotion.tiltServoAngle, tiltServo, faceMotion.desiredDelay);
    //continue until all have reached the desired position
    if (status1 == 1 & status2 == 1 & status3 == 1 ) {
      done = 1;
  }// end of while
int servoParallelControl (int thePos, Servo theServo, int theSpeed ) {
  int startPos = theServo.read();        //read the current pos
  int newPos = startPos;
  //int theSpeed = speed;
  //define where the pos is with respect to the command
  // if the current position is less that the actual move up
  if (startPos < (thePos - 5)) {
    newPos = newPos + 1;
    theServo.write(newPos);
    delay(theSpeed);
    return 0;
  else if (newPos > (thePos + 5)) {
    newPos = newPos - 1;
    delay(theSpeed);
    return 0;
  else {
    return 1;
void generateAction() {
  int waypoint = 0;
  int theJoint = 0;     // one of the joints in a trajectory array
  int trajSize = 0;
  int theSpeed = 0;
  struct headPos newPosition;
  newPosition.desiredDelay = theSpeed;
                                  ////////////////////////////////////////////////////////////////////////////////////////////////////HERE
  delay; 100;
  player.playMp3Folder(random(2, 98));
  delay; 1000;
  delay (random (1000, 2000)); //delay between ne motions
  theSpeed = random (1, 10);
  newPosition.tiltServoAngle = random (10, 120);
  newPosition.baseServoAngle = random (10, 170);
  newPosition.arielServoAngle = random (70, 130);
  moveTo (newPosition);
void checkMap() {
  //randomly cycle and move to positions to check if there is any item at that location. (create behaviors for moving to those locations without the
void storedAction(int positionSelected, int theSpeed) {
  int waypoint = 0;
  int trajSize = 0;
  if (positionSelected == 1) {
    // up
    int trajSize = 1;
    int trajectory[trajSize][5] = {{101, 65, 153, 75, 5}   };
    while (waypoint < trajSize) {
      newPosition.tiltServoAngle = trajectory[waypoint][theJoint];
      newPosition.baseServoAngle = trajectory[waypoint][theJoint + 1];
      newPosition.arielServoAngle = trajectory[waypoint][theJoint + 2];
      waypoint++;
  else if (positionSelected == 2) {
    //shake
    int trajSize = 9;
    int trajectory[trajSize][5] = {{97, 65, 130, 75, 5}, {97, 101, 130, 75, 5}, {97, 71, 130, 75, 5}, {97, 114, 130, 75, 5}, {97, 70, 130, 75, 5}, {97, 107, 130, 75, 5}, {101, 79, 146, 75, 8}, {101, 56, 146, 75, 8}, {101, 81, 146, 75, 8}   };
      waypoint++;
  else if (positionSelected == 6) {
    //nod head
    int trajSize = 9;
    int trajectory[trajSize][5] = {{97, 70, 130, 75, 5}, {97, 70, 117, 75, 5} , {97, 70, 141, 75, 5}, {97, 70, 112, 75, 5}, {97, 70, 143, 75, 5}, {97, 70, 115, 75, 5}, {97, 70, 146, 75, 5}, {97, 70, 115, 75, 5}, {97, 70, 144, 75, 5}  };
      waypoint++;
  else if (positionSelected == 7) {
    //hang and shake
    int trajSize = 55;
    int trajectory[trajSize][5] = {{101, 65, 111, 75, 12}, {101, 99, 111, 75, 8} , {101, 43, 111, 75, 8}, {101, 101, 111, 75, 8}, {101, 48, 111, 75, 8}  };
      newPosition.tiltServoAngle = trajectory[waypoint][theJoint + 0];
      newPosition.baseServoAngle = trajectory[waypoint][theJoint + 0];
      newPosition.arielServoAngle = trajectory[waypoint][theJoint + 0];
      waypoint++;
  else if (positionSelected == 9) {
    //excited
    int trajSize = 11;
    int trajectory[trajSize][5] = {{89, 76, 143, 5, 5}, {114, 76, 143, 5, 5} , {87, 76, 143, 5, 5}, {114, 76, 143, 5, 5}, {88, 76, 143, 5, 5}, {121, 76, 143, 5, 5}, {91, 76, 143, 5, 5}, {115, 76, 143, 5, 5}, {88, 76, 143, 5, 5}, {117, 76, 143, 5, 5}, {96, 76, 143, 5, 5}  };
      waypoint++;
      else if (positionSelected == 10) {
 //Jump
    int trajSize = 3;
    int trajectory[trajSize][5] = {{97, 70, 160, 75, 10}, {97, 70, 65, 75, 1} , {97, 70, 130, 75, 5}  };
           newPosition.desiredDelay = trajectory[waypoint][theJoint + 4];
      waypoint++;
  else {
    //nod head
    int trajSize = 9;
      waypoint++;
The code i'm wanting to implement is here:
Case 1.
Serial.println(“case 1.”);
      player.playMp3Folder(random(99, 103));
      delay(100);
      arielServo.write(130);
      delay(100);
      delay(100);
      delay(100);
      delay(100);
      delay(100);
      delay(100);
      delay(100);
      delay(100);
      delay(100);
and case 2.
Serial.println(“Case 2.”);
      delay(20);
      delay(20);
      delay(20);
      delay(20);
      delay(20);
      delay(20);
      delay(20);
      delay(20);
      delay(20);
      delay(20);
haven't quite figured out what i want for case 3 yet, but once i know how to implement it, i should be able to figure it out!
Thanks in advance!
Maybe show us you've even read the switch...case documentation and made a vague attempt???
Please start by posting your full sketch
What exactly is it that will determine which of 3 courses of action is taken?
You should also note that
does not do what the comment says because the upper value is exclusive
Thanks for the sarcastic reply. Every time i post here i get some sort of [EXPLETIVE DELETED] remark like this. The community here is toxic. I always spend a couple days working on something before i even consider posting here because the atmosphere is awful.
Well don't forget that the code in each case should end with a break;
But what is the switch variable, how do you come up with the one of three cases to execute?
The switch/case is just an elaboration and convenience for avoiding a bunch of if statements.
Can you write your intentions for the functionality like this?
   if  (switchVariable == 0) {
        doTheZeroThing();  // whatever, code, you know
    else if (switchVariable == 1) {
        doTheOneThing();
    else if (switchVariable == 2) {
        doTheTwoThing();
So you need to compute value, then it it easy to do one of three things on that value, either if/elsing your way through it or prettier with a switch/case.
HTH
a7
Thanks for the helpful comments, Some constructive, some not so much, but i've managed to fix it.
//This version works but still having issues with DFplayer dropping out and static sound, then rebooting at
//full volume. Potentially an issue with voltage, but will test with new PCB!
int Reset = 3;
Servo baseServo;
Servo arielServo;
Servo tiltServo;
struct headPos {
  int baseServoAngle;
  int desiredDelay ;
int ready = 0;
bool holder = 1;
  delay(200);
  delay(200);
  delay(200);
    delay (3000);
    delay (4000);
  ready = 0;
  noTone(buzzerPin);
int K = 2000;
    // Alarm Sequence
    //delay(5000);
    noTone(buzzerPin);
      generateAction();
      randomNumber = random(1, 5); // find a random whole number between the two values
      int i;
        generateAction();
    else { /////////////////////////////////////////////////////////////////////////////////////////////////////SURPRISE!!!
      switch (random(1,3)) {
        case 1:
      Serial.println("Excited.");
      delay(100);
      delay(100);
      delay(100);
      delay(100);
      delay(100);
      delay(100);
      delay(100);
      delay(100);
      delay(100);
      delay(100);
      delay(1500);
        case 2:
      Serial.println("Very Excited.");
      delay(20);
      delay(20);
      delay(20);
      delay(20);
      delay(20);
      delay(20);
      delay(20);
      delay(20);
      delay(20);
      delay(20);
      delay(1500);
        case 3:
        Serial.println("Sad.");
        player.playMp3Folder(random(104, 106));
        arielServo.write(175);
        baseServo.write(20);
        baseServo.write(160);
        delay(1500);
  return distance;
  int toneDuration;
  int numberOfWords;
    noTone(soundPin);
  //noTone(soundPin);
  int toneDuration;
  int numberOfWords;
  int toneFreq;
    noTone(soundPin);
  if (theDiff > 0) {
    // if ascending
      noTone(soundPin);
    noTone(soundPin);
  else {
      noTone(soundPin);
    noTone(soundPin);
  int status1 = 0;
  int status2 = 0;
  int status3 = 0;
  int done = 0 ;
      done = 1;
  }// end of while
    delay(theSpeed);
    return 0;
    delay(theSpeed);
    return 0;
  else {
    return 1;
  int waypoint = 0;
  int trajSize = 0;
  int theSpeed = 0;
  delay; 100;
  delay; 1000;
void checkMap() {
  int waypoint = 0;
  int trajSize = 0;
    // up
    int trajSize = 1;
      waypoint++;
    //shake
    int trajSize = 9;
      waypoint++;
    //nod head
    int trajSize = 9;
      waypoint++;
    //hang and shake
    int trajSize = 55;
      waypoint++;
    //excited
    int trajSize = 11;
      waypoint++;
 //Jump
    int trajSize = 3;
      waypoint++;
  else {
    //nod head
    int trajSize = 9;
      waypoint++;
There you go!
a7
You prolly want
random(1, 4)
as has been pointed out the upper limit is never returned.
Also, you could make it easier to read, modify and extend by moving the several many lines of each case into an appropriate named function that you call.
Cases are then very simply a call to a function and a break.
Details are in the functions, I don't needa read them if I don't care to.
Just a style thing… code is code and if it works and you happy, so am I.
a7
Amazing! Thanks for the advice! I had wondered why case 3 wasn't showing haha
You're quite welcome!
your problem is, you don't know where you are. you need to look around and get your bearings. the culture here is based on the people here. the people here are do it yourself people. if you do not show evidence of having studied first, you are not going to be treated kindly.
this is not a let's all hold hands and sing Kumbaya place. you want that, find a forum for writers. this is the kind place where "search term: random numbers" is a generous dose of help.
This place is Wesley Crusher knowledge and Worf attitude. It is not blue ribbons for participants.
You might want to use randomSeed() in the setup to help with the "randomness" of the random function.
Tom... :smiley: :+1: :coffee: :australia:
Thank you for your kind compliment, which I am happy to return!
Have a nice day and enjoy programming in C++ and learning.
I did warn you !
Yeah, i posted a Q and got "read the code" (over 3000 lines and they bitched when I only posted excerpts) as the 'fix'.
switch (value)
case 1:
// do whatever
// no fall thru
case 2:
// more stuff
default:
//anything not covered
